********* sub box fit issue
Discussion in 'Audio & Video' started by HusaUrDaddy, Apr 28, 2019.
  1. Apr 28, 2019 at 3:08 PM
    HusaUrDaddy
    HusaUrDaddy [OP] New Member
    Marty
    Fayetteville, GA
    2023 TRD Sport Crewmax 4x4 on order / 2019 TRD Pro CrewMax (sold)
    SQ1 package, Kenwood DDX9905 in the '19
    Hi all,
    I'm installing a ********* SQ1 system into a 2019 Tundra Crewmax TRD Pro. Midstream (day 5) into an install that should've taken two to three...Just figured out the sub box won't fit, period. Anyone else had / solved this issue?
    I installed the Ballistic matting as per their instructions. When trying to install the larger part of the rear seat (driver side), it stops against the sub box at the rear horizontal brace / bar. Did the '19's change the rear seat by chance? There's no way it will fit; at this point I can only guess that either the rear seat horizontal brace has changed, or the aft wall in the truck is somehow bulged forward an inch or so. We've tried to maneuver it in every possible combination but the end result is that it's about an inch shy, front to rear. No way it will fit, period. My only thought is to cut a relief into the front of the box to make room for the rear seat bar, then seal it from the inside like the cutouts for the other brackets.
    The pic shows the rear bar on the seat and the square I drew on the box shows about where the seat stops against it. The box is as far back against the rear panel of the truck as it can go, making contact.
    Anyone else run into this?? Thoughts? Thanks in advance.
  2. Apr 28, 2019 at 3:42 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    2LB Sledge would massage that brace right to where it needs to be.
  3. Apr 28, 2019 at 3:49 PM
    HusaUrDaddy
    Marty
    Fayetteville, GA
    Thought about it...but then it pushes the seat back forward making it unusable for a passenger. I bought the truck so all three kids could fit...
    birdman076 likes this.
  4. Apr 28, 2019 at 4:19 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
  5. Apr 28, 2019 at 4:58 PM
    HusaUrDaddy
    Marty
    Fayetteville, GA
    It’s a little late; entire thing is installed except for this stupid box...
  6. Apr 28, 2019 at 5:33 PM
    HusaUrDaddy
    Marty
    Fayetteville, GA
    Follow up...no way that box fits a Crewmax. None. I even cut a relief for the rear bar; when I did, the rest of the seat rested against the box, still at least an inch forward of where it needed to sit. I'll talk to ********* tomorrow, and I'm looking for a box as we speak. I'll update after talking with TT.
  7. May 4, 2019 at 2:57 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    You saved me a lot of money y not buying from them.
    Was going to order the 1700.00 kit
  8. May 4, 2019 at 3:22 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wow that really sucks. I have been hearing way to many negative comments concerning ********* lately. Glad I went with tech12volts.
  9. May 10, 2019 at 11:34 AM
    hypa
    hypa New Member
    I had a similar issue with my box, but after talking to ********* I realized I was overthinking it after a long day of installing.
    The seat actually holds the box in place. There are a few cutouts in the box itself that fit the lower brackets.
    What did you come up with HusaUrDaddy?
