Stupid question 1:AM
Discussion in '1st Gen Tundras (2000-2006)' started by Otakutoaster, Nov 16, 2024.
  1. Nov 16, 2024 at 11:03 PM
    Otakutoaster
    Otakutoaster [OP] New Member
    WI
    2002 Tundra AC limited Black V8 4wd
    Radio, subwoofer & amplifier, Roll-N-Lock, Cabin air filter,
    Why was my driver side turn signal so hard to get out. But the passenger just popped out with one pry. I ended up prying so much it released the lens. It released from all the bending to the housing.
  2. Nov 16, 2024 at 11:09 PM
    Tundras.com Forum Santa
    Tundras.com Forum Santa Milk and Cookies
    Santa
    3" Lifted Sleigh. sPOD lights on each reindeer. HeftyFab sliders
    Maybe a lot of left turns :notsure:
  3. Nov 17, 2024 at 5:50 AM
    The way to get them to release is not to pry on them, but the undo the fastener on the fender and from the rear to the front, give them a palm whack towards the front of the truck.
  4. Nov 17, 2024 at 7:09 AM
    shifty` I'm having daydreams about night things
    Yeah, prying is the wrong way to take those out.
    Stand next to your front wheel, and with all bolts off, slap-push (simultaneously) the turn signal forward. It will slide forward. It's the best way I've found to do it across multiple times taking mine out.
    KNABORES likes this.
  5. Nov 17, 2024 at 9:47 AM
    Otakutoaster
    WI
    That's probably why it came out so easy on my passenger side. I was pulling from the gap between the fender and the clip that connects to the headlight.
  6. Nov 17, 2024 at 9:49 AM
    Otakutoaster
    WI
    The only reason I even was prying was because in most of the videos I've seen. They say and show them prying it forward.
  7. Nov 17, 2024 at 10:01 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    I used a shoelace. Slide it behind the housing and pull
  8. Nov 17, 2024 at 10:20 AM
    Otakutoaster
    WI
    I did something similar and it made me stumble backwards when the clip released.
    Retired...finally likes this.
  9. Nov 17, 2024 at 12:48 PM
    Yeah, I dunno how to better explain it, but a simple forward palming of the housing.
    I hold my hand about an inch over the seam of the light housing and body - I'm not in pimp training here, I simply want my turn signal out - then sort of palm the housing inward-and-forward. I say "palm" it because the housing will go flying off.
    But this is the easiest way to get it out I was able to find and it works 100% of the time within 2-3 tries. If they've never been popped out, it's more difficult. But yeah, just want an inward-toward-engine push and slide forward with your palm.
  10. Nov 17, 2024 at 1:19 PM
    Otakutoaster
    WI
    I did end up doing that after not getting it out after 10 minutes but it didn't do anything other than break my lens. I think they've never been removed before. So after my lens broke I just pulled it until it unclipped.
    shifty`[QUOTED] likes this.
  11. Nov 17, 2024 at 1:22 PM
    Well hey, now you can easily remove the orange part and have clear corners :rofl:
