Stumped
Discussion in '1st Gen Tundras (2000-2006)' started by Fardept, Sep 8, 2025 at 12:17 PM.
  1. Sep 8, 2025 at 12:17 PM
    Fardept
    Fardept [OP] New Member
    Monday
    2004 Tundra SR5 4x4 V8 Regular Cab
    Lately, in the morning when I turn the key to start my 2004 Tundra, all I get is the normal lights, etc. but no ignition. And then later it'll start right up. And start no problem the rest of the day. This doesn't happen every morning, and sometimes not for days. It has a fresh starter and relay. Any guesses? And thanks for the help.
  2. Sep 8, 2025 at 1:00 PM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I'd say you need a new ignition.
  3. Sep 8, 2025 at 1:03 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So power, turn key, no crank? Does it lose any power at all when it no cranks? Have you verified that all of the grounds are tight?
    We can just throw guesses at it and you can spend your money until you tell us to stop.
  4. Sep 8, 2025 at 1:08 PM
    Fardept
    Monday
    When I turn the key to accessory all the proper lights, etc happen. Turn to ignition, nothing. Maybe a slight "dink"from the dash?
  5. Sep 8, 2025 at 1:11 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Were you have this issue prior to the new starter and new relay? What other electrical work have you done prior to this issue?
  6. Sep 8, 2025 at 1:11 PM
    Fardept
    Monday
    I appreciate the guesses. I'm thinking the ignition too, but my mechanic doubted that because of the lights, etc seeming normal.
  7. Sep 8, 2025 at 1:15 PM
    Fardept
    Monday
    Yeah, this has been going on for a while. I've dropped it at the garage and few times, but of course then it starts right up. The starter and relay last week was the first money I've thrown at it.
  8. Sep 8, 2025 at 3:50 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Have you tested the battery and cleaned the terminals?
    blenton likes this.
  9. Sep 8, 2025 at 4:12 PM
    Fardept
    Monday
    Yes. All good there. And thanks.
  10. Sep 8, 2025 at 5:12 PM
    This usually ends up being bad battery cables. Corroded inside. The ground cable is the likely culprit. Worth checking all of the engine grounds as well. I wouldn’t dismiss the battery terminals either. My no start condition recently was terminals that looked ok, but weren’t making good contact. I could wiggle them by hand if I tried hard enough.
  11. Sep 8, 2025 at 8:12 PM
    woodamsc
    woodamsc New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    did you check the fuel filter
  12. Sep 8, 2025 at 8:25 PM
  13. Sep 9, 2025 at 8:33 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s always the fuel filter.
    FrenchToasty likes this.
  14. Sep 9, 2025 at 8:58 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  15. Sep 10, 2025 at 6:44 AM
    Fardept
    Monday
    Found the problem. The previous owner had installed an aftermarket starter disabling device and it was tucked so far under the dash it was almost impossible to notice unless you were laying in the floor. My mechanic can't explain how it hasn't caused trouble before, apparently you're supposed to have some sort of fob on the key ring to start the truck. But anyway, thanks for the help everybody!
    Jack McCarthy likes this.
  16. Sep 10, 2025 at 6:46 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yup. See below
