Stumped on stopping.
Discussion in '2.5 Gen Tundras (2014-2021)' started by rotrwing44, Apr 19, 2023.
  1. Apr 19, 2023 at 5:16 AM
    rotrwing44
    rotrwing44 [OP] New Member
    I have 2014 Tundra, TSS 4x4, 5.7. I recently started to feel the brakes chattering like the rotors were warped. I replaced the rotors and brake pads. I didn't notice any issues while performing this work. However when I took it for a test drive after it was almost like I didn't replace anything. It did help but I can still feel the pulse when stopping. Could it be the rear rotors? Any ideas?
  2. Apr 19, 2023 at 5:24 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It could be the rear. Did you do the break in procedure for the new pads and rotors? Have you ever changed your brake fluid? Did you inspect your calipers? It sounds like its possible the pins need some lube.
  3. Apr 19, 2023 at 6:24 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    When you hit the brakes can you feel the pulsation in the steering wheel or seat..Usually steering means fronts, seats mean rears....And like mentioned above the rear calipers have slider pins that usually need lube.. If rear calipers pins are frozen then it will cause pulsating..
    rotrwing44[OP] likes this.
  4. Apr 20, 2023 at 3:28 PM
    rotrwing44
    I will look at both this weekend. Thanks for the info. Feeling it more pedal and seat.
