Stuck shifter leaver
Discussion in '2.5 Gen Tundras (2014-2021)' started by marconewt, Aug 22, 2021.
  1. Aug 22, 2021 at 6:14 PM
    marconewt
    marconewt [OP] New Member
    mark
    2018 sr5 tundra
    none
    I have 2018 Tundra, stock, the usual. Sometimes when I try to put the shifter into D, from P, it resists and refuses to go into D. Then I turn the truck off and restart it, and then keep diddling with the shifter, and by the grace of god, it allows me to put it into D after more frustrating diddling. I have no idea what this could be..... Maybe I'm the only one?
  2. Aug 22, 2021 at 6:15 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Try wiggling the steering wheel and see if that “unlocks” it next time……
    15whtrd likes this.
  3. Aug 22, 2021 at 6:29 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    So does it go to reverse or neutral? Column or floor shifter?
    I agree with @shawn474, try messing with the steering wheel to make sure the shift lock isn’t stuck there.
  4. Aug 22, 2021 at 7:02 PM
    Ó Brádaigh
    Ó Brádaigh New Member
    S. Polychronopolous
    21MGT
    Patiently waiting...
    Depress brake peddle
  5. Aug 22, 2021 at 7:44 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    If column shifter it's known for getting "stuck" in P if the trans is holding the weight of the truck on an incline. Unless its freezing out I use the parking brake 100% of the time when parked. Otherwise I swear I could do pullups off the shifting lever.
    When I park the truck, it's shifted to N, parking brake depressed, service brake pedal released, and shifter moved to P fast enough to not engage reverse. No more sticking issues after adopting that procedure
    15whtrd likes this.
  6. Aug 25, 2021 at 10:35 AM
    marconewt
    mark
    2018 sr5 tundra
    none
    its automatic trans w shifter on floor. Sometimes when i go to start the truck the lever will not move from the P position. I try to step on the brake for a few seconds longer prior to trying to shift into D, and still it makes no difference. Then i will turn the truck off and start it again and wiggle wiggle the lever. Usually it snaps out of its 'mood' and will go to D after repeated restarts. Thanks
  7. Aug 25, 2021 at 10:42 AM
    marconewt
    mark
    2018 sr5 tundra
    none
    the shift is on the floor and i do live on an incline. However this has also happened when i dont park on an incline.
    I will try your procedure using the Ebrake and Neutral when using park. Thanks!
  8. Aug 25, 2021 at 10:42 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Might be your shift lock solenoid then:
    https://parts.toyota.com/p/Toyota_2021_Tundra/Shift-Interlock-Solenoid/63179973/8543134010.html
  9. Aug 25, 2021 at 10:44 AM
    marconewt
    mark
    2018 sr5 tundra
    none
    ...again, a great tip i will try. This thing getting stuck in park is driving me nuts..
  10. Aug 25, 2021 at 10:47 AM
    marconewt
    mark
    2018 sr5 tundra
    none
  11. Aug 25, 2021 at 11:02 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
