Stuck in parking lot
Discussion in '2.5 Gen Tundras (2014-2021)' started by k9shag, Mar 25, 2019.
  1. Mar 25, 2019 at 10:12 AM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    came out of store turned key and got a click. Nothing turning over
    Door open light lights up and security lifht flashes. Checked battery terminals nice and tight and clean.any ideas
  2. Mar 25, 2019 at 10:14 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Have to lean battery or terminations. Have you tried a Jump start?
    15whtrd likes this.
  3. Mar 25, 2019 at 10:22 AM
    k9shag
    Tony
    Midland, NC
    Waiting either someone with cables or roadside whichever gets here first. Two year old battery.
  4. Mar 25, 2019 at 10:30 AM
    Trooper2
    JR
    Battery age never a definite determiner of health. Several have had original battery replaced as early as 1 year. Hopefully it jumps and you can have it tested and replaced if needed.
    TheBeast and Black Wolf like this.
  5. Mar 25, 2019 at 10:59 AM
    k9shag
    Tony
    Midland, NC
    Jump did not work but it did light up the dash and clicked a little. Im guessing the battery is done
    NewImprovedRon likes this.
  6. Mar 25, 2019 at 11:01 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    alternator?
  7. Mar 25, 2019 at 11:02 AM
    k9shag
    Tony
    Midland, NC
    Could be I guess.
  8. Mar 25, 2019 at 11:04 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like the battery. At least that’s the best place to start.
    Trooper2 likes this.
  9. Mar 25, 2019 at 11:04 AM
    Engine should still turn over even with a gimpy alternator. Betting on bad battery.
  10. Mar 25, 2019 at 11:15 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    What about headlights, turn them on and see if they are nice and bright.
  11. Mar 25, 2019 at 11:20 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    A dead cell in the battery will cause your symptoms. That can happen anytime. Don't skimp on a battery if you don't want that to happen in the future. A good quality AGM battery is worth it's weight in gold. Odyssey makes a good one but you can always go back with Toyota OEM.
    Watt maker and Lee's rig like this.
  12. Mar 25, 2019 at 11:50 AM
    k9shag
    Tony
    Midland, NC
    OK a jump from tundra to tundra did not work. Toyota Road service arrived and with a jump box it started. Drove 8 miles home turned it off and tried to start nothing. The battery gauge showed 14 volts on the ride home.
  13. Mar 25, 2019 at 11:52 AM
    You mean 14 volts.
  14. Mar 25, 2019 at 11:53 AM
    k9shag
    Tony
    Midland, NC
    yes sir
  15. Mar 25, 2019 at 11:55 AM
    k9shag
    Tony
    Midland, NC
    I have an appointment at the dealer for tomorrow morning. Gonna take the battery out and up to auto zone to have it tested today. I cant imagine the alternator is bad so soon.
  16. Mar 25, 2019 at 12:02 PM
    I'm thinking your alternator is good. Do you have a multimeter? If you do with engine running be careful and put positive DMM lead on alternator red positive and DMM negative to chassis ground, not alternator ground. Alternator should be indicating 14 volts ideally. Below 13 a bad sign above 15 not real good either.
  17. Mar 25, 2019 at 12:03 PM
    Trooper2
    JR
    Heard quirky things about dealers and batteries. Seems if warranted, they have to have truck and battery, and they need to install. They may not just give you a battery.
    Maybe should have drove straight there.
    Black Wolf and 15whtrd like this.
  18. Mar 25, 2019 at 12:20 PM
    k9shag
    Tony
    Midland, NC
    yeah thought about that, but had groceries that needed to get home, should have dropped them off left it running and then drove to Toyota. I am gonna take the battery now to the auto parts store to be tested. I can always call Toyota roadside assistance (free with my extended warranty) to jump me in the morning and take the whole truck. Just a pain in the ass
    Black Wolf likes this.
  19. Mar 25, 2019 at 12:52 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Replace the battery. Most "new" OEM batteries are junk. They've been sacrificed to the weight saving gods as manufacturer's literally chase iddy biddy bits of weight savings to tell the guvmunt they've done all they can to achieve compliance with the guvmunt MPG mandates.
  20. Mar 25, 2019 at 1:11 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Battery may have died all of the sudden. I had this happen once on my 2000 Tacoma. Left work stopped got gas. then stopped at a store. Came out would not start. Battery just all of the sudden went bad.
  21. Mar 25, 2019 at 2:41 PM
    k9shag
    Tony
    Midland, NC
    Thanks to al who have offered info here today.
    Took the battery in for testing it was dead. Called Toyota they advised because I was out of factory warranty the battery was no longer covered. I replaced the battery and all appears back to normal. I guess mentally I could not grasp a two year old truck needing a battery, but lets face it nothing is made today like it used to be, so we are done here.
  22. Mar 25, 2019 at 3:03 PM
    Trooper2
    JR
    Out of warranty?
  23. Mar 25, 2019 at 3:12 PM
    blizz86
    blizz86 New Member
    Mine died while it was still under factory warranty.. bought an odyssey 34r-pc1500 instead
    Deuxlatch and Black Wolf like this.
  24. Mar 25, 2019 at 4:43 PM
    What did you replace it with?
  25. Mar 25, 2019 at 5:14 PM
    Knicksfan76
    Knicksfan76 New Member
    2017 TRD Pro Cement Gray
    Went to Lowe's and got 15 pieces of lumber and 40 pavers (12" x 12"). Came out, went to start my truck and......nothing. My truck was dead, no juice. I drove there with no issues 15 mins prior and nothing was draining the battery. Any idea what the deal is? Are there sensors in the bed that shut the truck down if the payload is too heavy?
  26. Mar 25, 2019 at 6:04 PM
    Trooper2
    JR
    Guessing same mfg and maybe lot of OP's battery.....
  27. Mar 25, 2019 at 6:49 PM
    Yep....same year. Apparently the new bats do suck...
    Trooper2[QUOTED] likes this.
  28. Mar 26, 2019 at 3:24 AM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    2 years is still 1 year inside factory warranty.
  29. Mar 26, 2019 at 4:15 AM
    k9shag
    Tony
    Midland, NC
    43K miles isn't (3 years or 36K )
    landphil likes this.
  30. Mar 26, 2019 at 4:18 AM
    k9shag
    Tony
    Midland, NC
    Toyota True Start 84 month warranty
