Stuck in park
Discussion in 'New Member Introductions' started by SA73, Mar 16, 2019.
  1. Mar 16, 2019 at 7:02 AM
    SA73
    SA73 [OP] New Member
    New here with a 12 TRD. Hopefully this is an easy fix. Shifter won't come out of park unless I use the manual release. Thought it might be a fuse for the brake lights, but they are working. Any ideas where to check next?
    OR18TRD and Pinay like this.
  2. Mar 16, 2019 at 7:03 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  3. Mar 16, 2019 at 7:06 AM
    Did you confirm your blinkers and brake lights are physically working?
    Welcome
    JoshuaA likes this.
  4. Mar 16, 2019 at 7:13 AM
    SA73
    Yea they are all working. Thanks for the welcome.
    Pinay likes this.
  5. Mar 16, 2019 at 7:58 AM
    Welcome from Texas
  6. Mar 16, 2019 at 8:00 AM
    Welcome from NY.
    Pinay likes this.
  7. Mar 16, 2019 at 8:13 AM
    15whtrd
    15whtrd Mr. Blonde
    Any warning lights showing up?
  8. Mar 16, 2019 at 8:29 AM
    zlaneb
    zlaneb New Member
    Austin, TX
    Crazy idea but is the steering wheel locked, and if so, does it have any play in it?
  9. Mar 16, 2019 at 9:01 AM
    Welcome from Ohio.
    Pinay likes this.
  10. Mar 16, 2019 at 10:06 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  11. Mar 16, 2019 at 10:11 AM
    Welcome from CO.
  12. Mar 16, 2019 at 10:20 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and are parked on an incline without the foot brake on?:worthless:
  13. Mar 16, 2019 at 12:25 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI. If all your fuses are good and it's not just torque locked from being parked on an incline the next place to check (part to replace) is the brake switch. Fairly inexpensive and easy to swap out.
  14. Mar 16, 2019 at 5:41 PM
    SA73
    Thanks for all of the welcomes. Not parked on an incline. Steering wheel isn't locked. No warning lights. The brake switch you are referring to is at the brake pedal?
  15. Mar 16, 2019 at 5:44 PM
    Tempest
    Tempest You feel lucky??!!
    2015 Limited TRD
    Welcome from AZ! :tumbleweed:
  16. Mar 16, 2019 at 5:49 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    In the shifter there is a little solenoid that is powered by the brake light circuit, and you’re doing it’s job with the manual release. You could check for power and ground to it with your brakes applied.
    Any sugary drinks spilled in the shifter area? Yes or no, it might just be sticking.
    JoshuaA likes this.
  17. Mar 16, 2019 at 5:52 PM
    koditten
    Kirk
    Midland of the Mitten
    You checked the fuses under the dash and not just the ones under hood.
    Those under dash fuses are very hard to see. You have to meter them or pull them to tell if they are open.
  18. Mar 16, 2019 at 6:55 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado and sorry I don’t have any answers
    15whtrd likes this.
  19. Mar 16, 2019 at 7:23 PM
    Wes
    Wes New Member
    I had the same thing it was a fuse
    koditten likes this.
  20. Mar 16, 2019 at 7:49 PM
    koditten
    Kirk
    Me, too.
  21. Mar 16, 2019 at 8:59 PM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    Check your cargo light or courtesy fuse. Had the same thing happen and it was a fuse.
  22. Mar 16, 2019 at 11:15 PM
    SA73
    Thanks for all of the replies. Cargo light is good. I checked the fuses under the hood. I need to check the ones under the dash. Where is the solenoid and how do I get to it?
  23. Mar 17, 2019 at 7:55 AM
    duece292
    Greg
    Green Bay, WI
    Yes, it's at the top of the brake pedal arm.
    15whtrd likes this.
  24. Mar 17, 2019 at 7:58 AM
    15whtrd
    15whtrd Mr. Blonde
    To confirm whether the switch is working or not, does that same switch also turn on the brake lights?
  25. Mar 17, 2019 at 8:16 AM
    duece292
    Greg
    Green Bay, WI
    It does, but the brake lights working doesn't necessarily confirm that the switch is good. Besides turning the brake lights on and off it also tells the ECU to lock or unlock the gear shift solenoid, overrides the cruise and communicates with the ABS and ignition switch thru the ECU.
    15whtrd[QUOTED] likes this.
  26. Apr 3, 2019 at 7:22 AM
    Blademan
    Blademan New Member
    VT
    2016 LTD
    Just had this happen to me this morning as well. I checked under the dash and under the hood at the TAIL 15A fuse as well as under the hood with the 15A STOP all are good. Would the courtesy or cargo fuse really cause that to happen ?
  27. Apr 3, 2019 at 11:06 AM
    duece292
    Greg
    Green Bay, WI
    It could. Make sure you check all of the fuses related to your lighting, tails, tail relay, brakes, chmsl, cargo, etc. Welcome from WI.
    15whtrd likes this.
  28. Apr 4, 2019 at 5:20 AM
    Blademan
    Blademan New Member
    VT
    2016 LTD
    Hmmm well it took an interesting turn yesterday, ran through the fuses and pulled a few to look and all are still good and now my parking sensors are not working . . . I only pulled the TAIL, STOP, and towing ones. I did pull the brake sensor out of the mount to check continuity so I'm not sure if that has anything to do with coding with the system.
    Anyone got any thoughts as to why they parking sensors are not working after pulling some fuses ? In the back of my noodle brain I got this feeling that there is actually an on/off switch for it but I just can't remember
  29. Apr 5, 2019 at 1:49 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  30. Apr 5, 2019 at 8:31 AM
    Blademan
    Blademan New Member
    VT
    2016 LTD
    Ugh, I'm an idiot. I found the parking sensor switch when I went back out to truck so that is working again, stupid steering wheel is positioned just so that I cannot see the P switch so I never noticed it was off. So ya'll can disregard my parking sensor(s) issue above. Taking truck to stealer on Monday to have them figure out why I'm stuck in park when all my fuses & lights work. Will let you know what they find
