Stuck in or out of 4wheel drive?
Discussion in 'General Tundra Discussion' started by Seymourabel, Feb 4, 2020.
  1. Feb 4, 2020 at 1:38 PM
    Seymourabel
    Seymourabel [OP] New Member
    Robert
    Alaska and travel
    Tundra SR5
    I have a 2013 Tundra SR5 crew max 4x4.
    I use my 4wheel drive often and recently had a wheel speed sensor go bad while in 4 wheel drive. When this happens the 4 wheel drive is stuck where ever it is set, on or off.
    Does anyone know how to get it in or out of 4 wheel drive when the 4wheel hi and low lights in dash are blinking? The dealer did it for me when I had it diagnosed (but not repaired) for a bad wheel speed sensor and sub wire harness. I’ll fix it myself.
    I am often in places where I need 4 wheel drive (a long way from help) and when I have the same problems w/ sensor- harness, I would like to b able to do the switch to one or the other in remote areas.
    thanks in advance for any help in answering.
  2. Feb 4, 2020 at 2:00 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m wondering if a battery disconnect would do it?
  3. Feb 4, 2020 at 2:08 PM
    Seymourabel
    Robert
    Alaska and travel
    Tundra SR5
    Thanks for your reply but no, at least not for me. I Tried that. I have to fool the command box in to thinking it is reading the info from the wheel!?
    Thanks again.
    Bob and 15whtrd like this.
