Stubby Antenna Reccomendations
Discussion in '2nd Gen Tundras (2007-2013)' started by SouthWestGA, Nov 9, 2019.
  1. Nov 9, 2019 at 8:09 AM
    SouthWestGA
    SouthWestGA [OP] New Member
    Here’s my new-to-me 2007 CM
    What stubby antennae do y’all recommend?
    I almost never listen to the radio,so it would be purely cosmetic and to keep a lower profile
  2. Nov 9, 2019 at 8:27 AM
  3. Nov 9, 2019 at 12:25 PM
    BuilderBee
    BuilderBee New Member
    Southern California
    2017 Tundra Double Cab TRD SR5
    BakFlip MX4 Tonneau Cover Stubby Antenna Husky Floor Liners
  4. Nov 9, 2019 at 12:59 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Don't buy one, PM me your address and I'll mail you the one that was on my truck. It didn't pick up a signal very well, hence removing it and replacing it with a mid-length one.
    TundraDude18 likes this.
  5. Nov 9, 2019 at 1:17 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This post is pretty good. I went with the $8 from Autozone. They way you describe your usage it's worth a look.
    Just got back from my drive up near Central City. Actually way above around 11,000 ft. On the way up I stopped in Clear Creek Canyon. I had my stock antenna attached, and brought along a 13" Metra Roadworks carbon style, 7" Pilot stubby, 17" antennax, and a 14" Raptor shorty rubber. Yes you read that right. Shorty Rubber. I was tuned to KBPI, a fairly powerful station in Denver. I found a dead spot with the factory setup and pulled over. Swapped in the four aftermarket antennas. They all had no reception. I would have been surprised if otherwise. I then moved to a spot where the signal came, back but weak with stock antenna. Did the swaparoo again. The 17" Antennax received the signal but weak like stock. The 13" Metra and 7" Pilot both had zip for reception. The l4" Raptor rubber that I picked up at Auto Zone this morning because it looked cool actually got decent reception. It was $7.99 Go figure. I then drove up to my friends property above an old mining town called Apex. All the antennas had good reception even thought the typical Colorado spring afternoon thunder showed up making it too dicey to fool around any more. This was not the most scientific of tests but still practical. I think antennas 7" or less are really for top mount euro style mounting. They might have gotten better reception mounted on top of the cab instead of next to the windshield. Apparently price does not factor in with these particular antennas. I left the $7.99 14" Raptor antenna on. ( By the way, doing this test like I did would be a good excuse to the wifey to go 4 wheeling.)
    This is the thread
    https://www.tundras.com/threads/to-stubby-antenna-or-not-to-stubby-antenna.1590/
  6. Nov 9, 2019 at 1:40 PM
    SouthWestGA
    Thanks for the suggestions guys
    @MJoeP i sent you a message to take you up on your offer
    JMB likes this.
