Strut size
Discussion in 'Suspension' started by Slickrick73., Mar 6, 2024.
  1. Mar 6, 2024 at 9:53 AM
    Slickrick73.
    Slickrick73. [OP] New Member
    Richard M Angulo
    2018 Tundra SR5 Double Cab
    Wheels tires and Tiger running boards
    Hey, Guys, I'm trying to find out what size struts to order with a 3-inch front lift on my 2018 Tundra. Oh yeah, i do have rear tow bags as well. Can anyone point me in the right direction.
    Thanks!
  2. Mar 6, 2024 at 10:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Tundras dont use struts. What lift are you installing, a spacer? If so, you may want to rethink that. If you need new shocks then look at lifted coilovers instead of a spacer lift. Most reputable 2.5/3 inch lifts will be package deal, lifted front coilovers, matching rear shocks, etc. And ride and performance will be much better than a spacer lift.
    Need more info on that you are planning to do/install.
  3. Mar 6, 2024 at 12:07 PM
    Slickrick73.
    Richard M Angulo
    Danm autocorrect. I meant rear end shackles. Don't know if i should order 2 inches or 3 inch.
  4. Mar 6, 2024 at 12:19 PM
    frichco228
    2.5 gen Tundras have 2 inches of rake from the factory. So fully level if lifting the front 3 would be to lift the rear an inch. But if you to any towing or hauling with a level truck, it rides high in front with any loads or towing. So if it was my truck and I lifted the front 3 inches, I would lift the rear 2 inches to have an inch of rake.
  5. Mar 6, 2024 at 12:21 PM
    frichco228
    and you know rear shock replacement is not going to lift the truck right? Ride height comes from the springs, not shocks. Shocks just dampen the suspension movement while the front and rear springs support the truck and any load.
  6. Mar 6, 2024 at 12:22 PM
    Slickrick73.
    Richard M Angulo
    Perfect, thanks for the information!
  7. Mar 6, 2024 at 12:34 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Also Coachbuilder 2" or 3" shackles don't lift that much. Slightly more than half that which is listed on the website.
    Toytec advertises as lifted height
    Check the 6112 wheel tire thread. Tons and tons of examples with CB 1/2/3 and toytec shackles at both 1" and 1.5"
    Also what front lift? 5100? 6112? Hopefully not a spacer
