Strut Problema
Discussion in '2nd Gen Tundras (2007-2013)' started by Pines2007, Jul 10, 2022.
  1. Jul 10, 2022 at 4:58 AM
    Pines2007
    Pines2007 [OP] New Member
    2007 Tundra SR5
    I replaced the struts on my 2007 Tundra SR5 with just struts from OReilly due to emergency broken strut breakdown. The struts are shorter than what was on the truck but now the 4wheel drive will no work. This was my first struts replacement attempt. Is the problem due to using a cheap strut? Any advice? Not sure what to do now.
  2. Jul 10, 2022 at 7:05 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Sounds like they may have unplugged something or possibly nicked a wire while doing the job.
  3. Jul 10, 2022 at 8:50 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Wheel Speed sensor damaged, unplugged?
    Any trouble codes? ABS, Trac, lights on?
  4. Jul 10, 2022 at 12:20 PM
    Pines2007
    2007 Tundra SR5
    No just flashing lights
  5. Jul 10, 2022 at 12:22 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Which lights are flashing?
  6. Jul 10, 2022 at 12:26 PM
    Pines2007
    2007 Tundra SR5
    The 4 high. You can hear it trying to engage but doesn't. Also, the struts we put on lowered the truck about 2 inches. Would that have caused a problem
  7. Jul 10, 2022 at 12:27 PM
    Pines2007
    2007 Tundra SR5
    Don't know if we have to take it to the dealer or auto shop now to get it going.
  8. Jul 10, 2022 at 12:27 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The height thing really isnt a problem. The wheel speed sensors could be. There is one on each wheel and tire. Does the truck have an trouble codes? Have you unhooked the battery for 30 mins to let the ECM reset. Mine sometimes doesn't go into 4Hi smoothly but for the most part it works well.
  9. Jul 10, 2022 at 12:37 PM
    Pines2007
    2007 Tundra SR5
    I will try that. Thanks.
