Strut mount (top hat), KYB or OEM
Discussion in 'General Tundra Discussion' started by BIGUGLY, Jul 27, 2022.
  1. Jul 27, 2022 at 4:59 AM
    BIGUGLY
    BIGUGLY [OP] I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    So going to replace the suspension on the front of the truck. Figure new strut mounts would be a good idea.
    So KYB looks to be an option and are coming in about 60 bucks cheaper per side than the OEM.
    So is the KYB a suitable replacement or is the OEM that much better?
  2. Jul 27, 2022 at 5:26 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Sixty bucks is sixty bucks however with stuff like that OEM is the only way I would go personally. Simply because I feel that Toyota parts are higher quality than most aftermarket replacement parts.
  3. Jul 27, 2022 at 5:41 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    No experience with the front, but I replaced my leaking rear shocks with KYB Gas-A-Just shocks. Only have a couple thousand miles on them, but they are a little firmer than stock and seem to be good quality.
    You weren't asking about rear shocks, but the reason I responded is in my research I noticed that KYB is made in Japan, and they supply factory components to several different manufacturers (Toyota included). It didn't say exactly which components... but I take that to show they should be a decent replacement part supplier. At least they're not an Amazon special sourced by some dude in his basement and made in China. If the part looks comparable to OEM in size, fit, and build quality I'd be comfortable running it.
    BIGUGLY[OP] likes this.
  4. Jul 27, 2022 at 5:56 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Good to install new strut mounts but not always necessary. Have installed KYB shocks, struts and strut mounts on various Toyotas in the past. It is a quality brand name and will continue to install them in the future. Rockauto is a good place to source them. Bilstein also good alternative.
    Jernik likes this.
  5. Jul 27, 2022 at 7:23 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    KYB are just as good as the factory top hats.
    I have them on my truck and they are going just fine.
    Jernik likes this.
  6. Jul 27, 2022 at 8:13 AM
    BIGUGLY
    Paul
    2018 Limited
    Thanks all, much appreciated.
