Stroke Sensor/Engine Control System
Discussion in '2nd Gen Tundras (2007-2013)' started by Wastepro87, Aug 2, 2021.
  1. Aug 2, 2021 at 7:04 PM
    Wastepro87
    Wastepro87 [OP] New Member
    James
    2007 Toyota Tundra Limited crew cab
    07 Toyota Tundra limited crew cab 5.7 Trd. The other day i noticed my transmission abruptly acting off, especially goin into 1st, 5th and 6th gears, an hour later I get the VSC off light blinking along with Engine light on and Trac light on. I carefully finished my trip home. I caught myself looking over almost every wire including speed sensors on tires, I initially thought it was something to do with the API system which is bypassed on my truck. I was able to put an OBD reader on it and pulling the codes C1201 and C1247, which are Engine Control System Malfunction and Stroke Sensor. It also is reading a shift lever failure but that seems to be working fine, no code. I reset the alarms on the dash by taking negative terminal off for 5 minutes. The truck is still having problems with the transmission hard shifting mainly in 5th and 6th gears with a very slight feeling of power loss. Any help with what this may be would be greatly appreciated. Can a faulty stroke sensor cause this?
  2. Aug 2, 2021 at 7:16 PM
    Wastepro87
    James
    The truck has 175,000 miles and there are no transmission or powertrain codes that the obd read. I have owned it 2 years.
  3. Aug 3, 2021 at 9:18 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Have you ever changed the transmission fluid?
  4. Aug 3, 2021 at 9:37 AM
    Wastepro87
    James
    I haven’t, I’ve put 25k on truck. I need to see if car fax says anything. Could the level or fluid quality affect certain gears? I found out it doesn’t have a dipstick and only a sightglass.
  5. Aug 3, 2021 at 9:44 AM
    audiowize
    Paul B.
    Yes, the fluid quality will affect the operation of the transmission. I would do a drain and fill (be sure to do some research on how this is properly done, it's not super straightforward), then drive 100 miles, then repeat 2-3 more times.
  6. Aug 3, 2021 at 11:18 AM
    Wastepro87
    James
    Thank you.
  7. Aug 4, 2021 at 4:13 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I’m gonna go out on a quick google search limb and say the c1247 code will earn you a new brake booster. That should take care of the other code too.
    Edit: not sure if any of that will affect the trans unless it’s in limp mode.
    Edit again: maybe the trans was in limp mode and now it just needs to relearn you driving habits after battery disconnect.
  8. Aug 4, 2021 at 5:51 PM
    Wastepro87
    James
    Ok, appreciate the advice. Im gonna tackle some of these problems on my off days. I was considering which was more important first to take care of. I just figured with any major issues to the trans it would of sent codes but none.
  9. Nov 1, 2022 at 11:16 AM
    Miketundra1153
    Miketundra1153 New Member
    My exhaust pipe keeps needing a yearly patch since it broke just before the rear end so, it broke and it fell and was dragging the ground so I unhook the rubber hanger and pull it out hitting things underneath and now my 4hi4lo abs and traction
    Lights are all on!! So probably bumped a wire or whatever was running across the rear end never had this and I’ve done the emissions crap last year so it’s not those codes or lights just saying
