Stripped inverted flare nut on caliper
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, Jul 25, 2022.
  1. Jul 25, 2022 at 2:16 PM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    So I noticed a small leak a day ago and just got around to investigate today. Has anyone had the nut on the hard line going to a caliper be stripped and not end up buying a new caliper?
    I have a new hardline on order but didn't know it was stripped at that time. My guess nos that the caliper internal threads are of stronger metal but my luck is that I'm gonna get a new line and then need a new caliper.
    I should just have done the braided lines but we won't go down that road again right now, someone got banned for going off the planet last time.....
  2. Jul 25, 2022 at 3:06 PM
    Aerindel
    Aerindel New Member
    Montana
    I would get a tap and re-thread the caliper. The threads ARE harder than the brake line nut but re-threading is good insurance to clean up any metal squished in there and repair the threads if damaged. I *think* its M10 threads.
    No idea what this means.
    des2mtn and FrenchToasty like this.
  3. Jul 25, 2022 at 3:17 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Oh. I had asked a question about brake braided SS brake lines a while back turned into a mess. It wasn't necessary I suppose. I was just thinking that if had done that I wouldn't be dealing with this now.
    YardBird likes this.
  4. Jul 25, 2022 at 3:19 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Braided lines still have that same hardline to the caliper, so you’d still be in the same boat
    des2mtn and YardBird like this.
  5. Jul 25, 2022 at 3:25 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Ahh. I thought about getting them all the from where the rubber starts and yo the caliper. Isn't that what some people go with when lifted. Seems there's usually a banjo bolt on the back of the caliper afterwards.
    @Aerindel thanks for the input. Never rethreaded a caliper. Guessing this should be done slowly and vacuumed out? Cant imagine the shavings would be good inside the internals of caliper? You ever done this?
  6. Jul 25, 2022 at 3:40 PM
    Aerindel
    Aerindel New Member
    Montana
    Yes, but not the same situation as you. What happened to me was that I had a tire chain brake and rip the brake line out of the caliper in the front so I had to use a broken bolt remover to get what was left of it out of the caliper. I re-tapped the caliper just to make sure I didn't have any issues cross threading or anything when I replaced the line since it was kinda bunged up.
    Its not hard, just go slow and easy. You're not cutting new threads so it should go in pretty easily. If you put a little grease in the hole first it makes breaking the tap less likely and catches the shavings, which you can then clean out with a q-tip afterwards. No, you don't want shavings in the caliper but taps tend to pull shavings OUT rather than push them in so its not a big worry as long as you are moderately careful. Really, you just have to look at it and make a judgment call as to how your threads are afterwords. You should be able to have some idea if they are good or not when screwing the new brake line nut in after cleaning up the threads.
    If you don't have access to a tap (they are pretty cheap if you just need one) you can cut a slot in a hardened bolt of the same size, to make it look like a self taping sheet metal screw, and run that in and out a few times to repair the threads.
  7. Jul 25, 2022 at 4:47 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    That sounds like a better idea than the little metal line, two less parts in the brake system to fail
  8. Jul 26, 2022 at 2:19 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    It looks like it might have been cross threaded. After the female threads in the caliper are clean, make sure you can thread the new fitting several turns by hand before you get a wrench on it.
    Hi06silver[OP] likes this.
  9. Jul 26, 2022 at 7:30 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Going to a one piece can be done, but the concern I have about is that's a lot of unsecured line that can move around and get caught. If it's not secured to the spindle like the two piece OEM design, the lower part of the hose near the caliper would be a lot closer to the coil spring as the suspension travels.
    Also, I highly recommend getting a flare nut wrench for brake fittings - they don't round out fittings as easily as box end wrenches. https://www.amazon.com/Sunex-980906...845714&sprefix=10mm+flare,aps,265&sr=8-7&th=1
    nickrick78 and Casper421 like this.
  10. Jul 26, 2022 at 7:57 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just zip tie the shit out of it and that's not an issue :D
    FrenchToasty and des2mtn[QUOTED] like this.
  11. Jul 26, 2022 at 6:06 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Thanks for the input y'all. Got the new line in after tapping. All went well except when I went bleed them...broken bleeder screw. At least it's not open!
    Aerindel, FrenchToasty and des2mtn like this.
