stripped hex head
Discussion in 'General Tundra Discussion' started by smslavin, Sep 13, 2017.
  1. Sep 13, 2017 at 5:19 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I was going to finish installing the rest of my Bud skids this evening but one of the hex heads was super tight and super soft. It is now round. I imagine the alignment guys dropped the skids the other day and cranked it when they put the bolt back in. What's the best way to get that thing out of there? It has a rounded head and sits flush with the skid.
  2. Sep 13, 2017 at 5:24 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Vise grips?
    SouthBoundSteve likes this.
  3. Sep 13, 2017 at 5:27 PM
    Pics
  4. Sep 13, 2017 at 5:39 PM
    smslavin
    Hudson Valley
    Some stuff
    tried those. can't get a grip on it.
    i'll try and grab one in a few.
    mdavis[QUOTED] likes this.
  5. Sep 13, 2017 at 5:42 PM
    Screw extractor?
    15whtrd and zcarpenter92 like this.
  6. Sep 13, 2017 at 5:42 PM
  7. Sep 13, 2017 at 5:48 PM
    TRD-ROCKWARRIOR
    TRD-ROCKWARRIOR New Member
    Jerico
    2011 Black Tundra CM 4X4 TRD RockWarrior
    smslavin[OP] likes this.
  8. Sep 13, 2017 at 5:48 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  9. Sep 13, 2017 at 5:49 PM
    smslavin
    Hudson Valley
    Some stuff
    Thanks for the vid @Sean266 . That's perfect. I have everything but the replacement bolt. Hardware store run tomorrow.
    T-Rex266 likes this.
  10. Sep 13, 2017 at 9:20 PM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    If those don't work you will have to drill it completely out. make sure to use a smaller bit than the threads.
  11. Sep 13, 2017 at 9:24 PM
    RasTafari48
    RasTafari48 New Member
    Yup that's the only way. Use left handed drill bits if possible. Start with small drill bits and work your way up. Might need to tap new threads also
    kenomouth64 likes this.
  12. Sep 13, 2017 at 9:57 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Buying a new Tundra isn't an option? :D
  13. Sep 14, 2017 at 2:27 AM
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    Weld a flat washer to the top of the bolt, then weld a nut to the washer, put wrench on nut and turn
  14. Sep 14, 2017 at 2:39 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    If it's that tight this could and probably will be the only option. Drilling it out might be dicey and destroy internal threads.
  15. Sep 14, 2017 at 7:44 AM
    smslavin
    Hudson Valley
    Some stuff
    I'm going to give the star key method a try later this afternoon. Side note, I did trade a few emails with Bud asking about the size of the bolt. He replied with the size but then said he would pop a few in the mail this morning so I wouldn't have to go hunting around. Pretty awesome and very much appreciated.
  16. Sep 14, 2017 at 8:00 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  17. Sep 14, 2017 at 8:20 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The best extractor out there in many cases.
    Patriot likes this.
  18. Sep 14, 2017 at 10:02 AM
    Patriot
    Patriot Member
    Good luck, I hope you get it out.
