Stripped front stabilizer bar bolt
Discussion in 'Suspension' started by Sas, Sep 24, 2018.
  1. Sep 24, 2018 at 8:05 AM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I'm planning on leaving the front stabilizer (sway) bar off, but I do still need the bolts for the reservoir mounting plate for the shocks. However, I managed to strip one of the bolts and muck up the hole a bit as well. I need to get back under the truck to assess what can be done but I wanted to check here first to see if anyone had any ideas here first. Just to be clear, it's one of the two bolts that connect to the frame, not the one going into the LCA.
  2. Sep 24, 2018 at 8:19 AM
    Sas
    OKC, OK
    That's my first inclination, but I don't have one yet, so I wasn't sure if there was a block or something in the frame that the bolt is going into that could be replaced cheaper.
  3. Sep 24, 2018 at 8:30 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
