Stripped Deck Rail Screw Hole
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ronel2020, Nov 3, 2019.
  1. Nov 3, 2019 at 5:14 AM
    Ronel2020
    Ronel2020 [OP] New Member
    I tried to remove my deck rails to install a tonneau cover and found a stripped torx head bolt (likely from whomever installed the bed liner). I was able to drill out the bolt, but it seems as though some of threads of the original bolt remain since I can’t install a new screw (same size bolt as the original). The threads of the new bolts get stripped when I try to screw in the new bolt. How to I retap this bolt hole so that it is functional again? Thanks!
  2. Nov 3, 2019 at 5:46 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    RitcheyRch, 15whtrd and Pinay like this.
  3. Nov 3, 2019 at 6:29 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I'd get a wire bore brush and try to get the threads clean from the old bolt. Then try to cut what's left out with a tap.
  4. Nov 3, 2019 at 4:00 PM
    Ronel2020
    Thanks will try these and let you know what works. Appreciate the tips!
  5. Nov 3, 2019 at 5:16 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I'd not worry much if it's in the middle. Skip it unless you're anal like me
    SuperWhite20 likes this.
  6. Nov 3, 2019 at 9:11 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    From working on rusted out cars for a long time...
    If you’ve drilled through the old bolt and just the threads remain, you should be able to chase the remaining metal out with a tap. If this fails, you can just tap the hole for the next size up, and buy the slightly larger bolt you need.
    RitcheyRch likes this.
