Strange noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mas93, Oct 12, 2024.
  1. Oct 12, 2024 at 5:41 PM
    Mas93
    Mas93 [OP] New Member
    2018 Toyota tundra
    I have a 2018 tundra that makes a whining/ chirping noise when the engine warms up. The noise is not that loud when it is in but when you put it in drive it gets louder. So far I have replaced the serpentine belt, idler and tensioner pulleys and a new fan clutch housing assembly. The water pump housing is tight and not leaking and the AC compressor is working fine. It has been doing this for around a year and I'm clueless at this point.
  2. Oct 15, 2024 at 6:12 PM
    CoreysSilverTundra15
    CoreysSilverTundra15 New Member
    I’m experiencing the same issue you are having
  3. Oct 16, 2024 at 4:28 AM
    nkyrental
    nkyrental New Member
    Kevin
    2022 Chevrolet Silverado 3.0 Duramax
    Had that on my 2019, turned out it was the alternator.
  4. Oct 19, 2024 at 3:34 AM
    tundramike23
    tundramike23 New Member
    Michael
    Tyler, Texas
    2015 Toyota Tundra Platinum
    Momentum GT Cold Air Intake/ Bilstein 5160 Series/ Ironman 4x4 Raid Series Front Bumper w MONSTER WINCH./ Ironman 4x4 32" Lightbar w Light Cubes/ CBI Toyota Tundra Overland Rock Sliders/ JS 3000w High Output Alternator + Big3 Kit/ Pedal Commander
    Just had a very similar issue. Also noted that the sound would sometimes get worse with RPMs.
    I went through the same process of replacing belts and pulleys trying to figure out what was causing it.
    The alternator finally completely died on me, which made finding the problem easy.
    Just got it swapped out finally two days ago, the sound is completely gone now.
  5. Oct 29, 2024 at 6:16 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Same I am thinking alternator also at this point. I used a wooden dowel to listen and it def sounds like alternator
  6. Oct 29, 2024 at 7:18 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Be careful when blaming the alternator. I fell into this trap with my Tundra as well. Alternators have brushes in them and make completely different sounds and harmonics. I changed a perfectly good alternator for no reason and am still chasing a noise I don’t like.
  7. Oct 29, 2024 at 10:11 AM
    parkerbows
    Jack
    hmmm great
  8. Nov 1, 2024 at 8:42 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Power steering fluid level is good? Does the noise change at all with rpm speed or vehicle speed?
  9. Nov 2, 2024 at 7:07 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    They might be old school and look silly, but a mechanic's stethoscope is very cheap and works like a charm on things like this. I used to use a long screw driver up to the ear like my long since passed mechanic grandad and it worked too, but the stethoscopes on Amazon or at Harbor Freight with the rod extensions are far better. Less than $10 at HF.
