Strange Butt Massage
Discussion in '1st Gen Tundras (2000-2006)' started by RoninGSX, Jun 10, 2023.
  1. Jun 10, 2023 at 12:49 AM
    RoninGSX
    RoninGSX [OP] New Member
    Nic
    Tucson
    06 AC SR5
    2" Bilstein lift 1.25" Spidertrax wheel spacers BFG A-T K02 285/75R16 Front/Rear Eaton E Locker Yukon 4.56 gears K&N Filter
    Yes, the title is correct. I am getting a strange butt massage when I put the truck under load at speed. 2" shock leveling kit (F and R) with 35" KO2 A/T tires.
    To further clarify. Tires have been balanced and rotated twice (little bit of cupping but that's because both L and R LCA front and rear bushings are shot, next repair) so it's not a tire shimmy. At speed (anything above 5ish mph) without throttle, no massage. At speed with cruising throttle (light pedal), no massage. At speed giving some go go juice, definitely a butt massage.
    Replaced the throwout bearing with a brand new Toyota OEM part. I'm not 100% sure, but I believe it started after. Could be a possible bad bearing/rubber bond?
    Have drive shaft out and down at the drive shaft shop. Was thinking maybe a u-joint was bad or even that weird wobbly doohicky that joins the two shafts. Turns out everything is pretty solid. Just waiting to hear back about the balance.
    Last thing I can think of is maybe the rear diff is shifting (up or down) under load and acceleration causing a weird angle on the u-joint causing a wobble in the drive shaft?
    Anyone have experience with this or any other ideas?
  2. Jun 10, 2023 at 1:19 AM
    Aerindel
    Aerindel New Member
    Montana
    On other vehicles I've had torque vibration in the body, (what it sounds like your describing) from in-board, CV joint wear. (assuming you have a 4WD truck)
    This would be my first guess after U joints.
  3. Jun 10, 2023 at 3:21 AM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    Yes, it's 4WD. Vibration occurs with 4WD both engaged/disengaged. Not sure if that'd make a difference with this issue but I'll give them a check. The driver side CV is new after my diff rebuilds but the vibration happened way after the rebuild. At least 5k miles now.
  4. Jun 10, 2023 at 9:16 AM
    shifty` Bohannon Bohannon Bohannon Bohannon
    Does the vibration continue when you let off the gas pedal?
    Does the vibration increase/decrease to match speed?
    When was the last time you greased the entire driveline, including all yokes, shafts, etc.?
    When was the last time you adjusted your rear brakes?
    RoninGSX[OP] and JasonC. like this.
  5. Jun 16, 2023 at 10:49 AM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    It does not. As soon as I put a med to heavy load it it comes back. At a cruising load (just a wee bit of pedal) it is not there.
    I don't know that I've actually paid attention to this part. I will find out later tonight on my drive home.
    I just had the entire drive shaft out and down at the shop. All ujoints, yolk, and weird Toyota wobbly joint all checked out fine. They were greased up and the entire drive shaft was balanced with carrier bearing. Need a little weight up front (2 washer stack) and 1 in the rear. Vibration is still there bit not nearly as bad.
    Ya I probably need to do this. Just recently started a squeal but think it might just be brake dust. Need to pull the wheel and verify though.
    The drive shaft shop guy said that the rear diff could be articulating up and down thus causing a bad angle on the ujoint and thus creating a wobbling of the drive shaft. Was thinking of mounting my go pro under there to see but haven't had a chance to do that yet.
  6. Jun 16, 2023 at 12:09 PM
    That's a pretty classic symptom, hence why I ask. I tend to get this backwards sometimes, but IIRC, loss of vibration when letting off the pedal at speed is usually indicative of u-joint or carrier bearing problem. General logic is, and why I'm remembering it this way (my memory sucks), when you let off the gas, the driveshaft is putting near-zero realtime load on the bearings/joints. The moment you re-engage and apply enough load, you're engaging the faulty bearing assembly, and vibration returns.
    I know the shop told you your carrier bearing and u-joints are fine, but I'd be skeptical just because of that one symptom. IMO, u-joints are easy enough to DIY replace with needlenose, hammer, and a socket or dowel. I prefer Dana, Spicer, or Moog if I'm replacing. I prefer u-joints with zerks, personally.
    Note that other people have found similar symptoms because the carrier bearing housing wasn't fully secured, wrong bearing was installed, was installed backwards, or because they didn't clock the driveshafts correctly when replacing the bearing. YMMV. But that's my take on it.
  7. Jun 16, 2023 at 12:44 PM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    I appreciate the reply Shifty. I will most likely end up doing the ujoints sooner than later. Apparently the wobbly shaft connector is replaceable as well so I'll look into that. My other option that I started research was just doing a 1 piece but that's a long drive shaft and may cause more problems.
    Carrier bearing is a brand new oem from Toyota. I was worried that maybe I had a faulty one but not sure how to even test that. So said it appeared to be good
    shifty` likes this.
  8. Jun 16, 2023 at 12:50 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    This helped me get mine back together when i didnt mark the alignment.
  9. Jun 16, 2023 at 2:03 PM
    When you said "wobbly shaft connector" I thought you were talking about the carrier bearing. Got a pic of the part you're talking about?
  10. Jun 16, 2023 at 2:04 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i'm guessing the double cardan.
    shifty`[QUOTED] and Schcoman like this.
  11. Jun 16, 2023 at 3:26 PM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    :rofl:I've seen posts noting the alignment of the joints as well. I'm certainly not an expert, good thing we have Shifty!:yes:
    Sierradevil likes this.
  12. Jun 16, 2023 at 3:43 PM
    SD Surfer
    Bruce
    So Cal
    Before you just go fixing stuff willy nilly, you know some people pay a lot of money for strange butt massages right? (I mean, that's what I hear) :bananadance::dancingbacon::broccoli::kona::locked::taco::jellydance:
  13. Jun 17, 2023 at 7:28 AM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    Thanks for posting this! I always mark drive shafts before I pull them but this will help me to double check.
  14. Jun 17, 2023 at 7:29 AM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    Yes that's what I meant! Couldn't remember the name of it lol
  15. Jun 17, 2023 at 7:31 AM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    Lmao. Pretty sure with the price of gas, this would have been up there with the expensive ones (seeing how it was only happening under acceleration)!
    SD Surfer[QUOTED] likes this.
  16. Jun 17, 2023 at 7:56 AM
    18" TRD Off Road Wheels
    Pardon my ignorance if this doesn't apply to a 1GT or if I missed it, but did you do a carrier bearing drop after the lift? On my Turd Gen I had a small lift and slightly larger tires put on, and I needed a carrier bearing drop to address a little vibration under load. As soon as that was in the vibration was gone.
    FrenchToasty likes this.
  17. Jun 19, 2023 at 9:49 PM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    I did not do a carrier bearing drop. I dropped the front diff with spacers but not the carrier. Should I have done that? Read a bunch of post about leveling kits and lifts but hadn't read anything on the bearing.
  18. Jun 20, 2023 at 3:50 AM
    I can't say for certain because my truck was a 2019, but I didn't do a diff drop. Just a carrier bearing drop from Coachbuilder. Without it I had a bit of vibration.
  19. Jun 20, 2023 at 5:58 AM
    On the 1st gens most folks don't need to do much of anything except extended swaybar links (up front though) unless you go over 3". No diff drop, no carrier bearing drop. After 3 - 3.5" I'd be scrutinizing angles, myself, but you got plenty of guys on here at 3" who have neither dropped. I bought diff drop for my lift, but won't bother installing it. At $35, it was more of a "just in case". I wouldn't recommend installing one unless immediately after lifting you found symptoms indicative of an issue.
    GODZILLA likes this.
  20. Jun 20, 2023 at 6:02 AM
    Kung
    KG, VA
    Am I the only one wondering "....as opposed to a familiar butt massage?"
    RoninGSX[OP] and Sierradevil like this.
  21. Jun 22, 2023 at 7:18 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Mine doesn't have one, the angle isn't severe. It ain't dead nuts straight but I don't believe it's caused.me any vibration from down yonder to the extent in this post. I'm thinking if we can get some pictures of the OP's drive line someone may be able to tell of the carrier etc has actually been replaced/ greased like previously mentioned
    shifty`[QUOTED] likes this.
  22. Jun 24, 2023 at 10:44 PM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    I did the replacement myself a few months back with an OEM one from the dealership. Had an autoparts store one on for a few years and seemed to be replacing it every 1-1.5 years. Figured they were just sh*t quality. But never had any vibrations. Drive shaft shop said the same and that the drive shaft wasn't actually too far off. The rebalanced shaft did reduce the vibration a bit but not completely. I'm pulling the rear ties and drums tomorrow to adjust the brakes as shifty mentioned.
    I can't recall any one thing that might have started the shimmy, it just kind of started. Only major things I absolutely still need to do are replace both LCA and steering rack. Maybe the LCAs being fugged up (both sides, front and rear bushings) is causing a general truck vibration under acceleration but I'm not sure.
  23. Jun 24, 2023 at 10:45 PM
    RoninGSX
    Nic
    Tucson
    06 AC SR5
    I try to be as entertaining as possible in my descriptions of things!
    Kung[QUOTED] likes this.
  24. Jun 25, 2023 at 4:20 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I just skimmed the thread. Has anyone mentioned the needle bearing? Are you getting any noises or just the butt massage?
  25. Jun 25, 2023 at 7:13 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I don't think so, have you done that on yours yet? I'll probably do mine when I collect the parts to do the boots and what not. Boots arent ripped but I do sling some grease.
  26. Jun 25, 2023 at 10:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes I did mine and replaced it with the ECGS part. This is the way. @FrenchToasty will loan you his special tool if you send him good vibes and a beer.
  27. Jun 25, 2023 at 4:28 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    It doesn't look like that bad of a job or technical at all more messy than anything. I'll look up that thread I've read it several times, actually probably in 1 of my 51 tabs currently.
    RoninGSX[OP] likes this.
