Stored codes for 4 x 4
Discussion in '2nd Gen Tundras (2007-2013)' started by A4x4nutt, Apr 19, 2021.
  1. Apr 19, 2021 at 12:08 PM
    A4x4nutt
    A4x4nutt [OP] New Member
    2009 tundra
    3 inch lift 295/70/18
    Has anyone ever seen these codes .
    U0114 .
    Faulty four wheel drive clutch control module
    Having issue with 4hi light flashing no 4 wheel high or low.
    Thanks in advance
    2009 tundra crew 5.7
  2. Jun 23, 2021 at 10:05 PM
    Ianstundra
    Ianstundra New Member
    Ian
    I am having the same issue. Bump
  3. Jun 24, 2021 at 2:08 PM
    A4x4nutt
    2009 tundra
    Same codes ??
    Or just no 4x4 ?
  4. Jun 25, 2021 at 12:40 PM
    Ianstundra
    Ian
    Same codes and no 4x4
  5. Jun 27, 2021 at 4:51 AM
    A4x4nutt
    2009 tundra
    I just got my hand a complete wiring schematic and purchased a new 4x4 ecu .
    Plugged in the ecu but still no difference.
    I will be tracing some wiring today and cleaning the actuator motor on the transfer case .
    I do have a power probe so I will send power to the front add first.
    From what I hear 60 percent of the time it's the front add.
    But the went on the tranfercase motor was split and hanging off so it's most likely going to be that. Do lots of research before removing the actuator motor. It can be a little tricky .
    Make sure set the parking brake and block the wheels because it also controls park linkage .
    Tundrasolutions.com has some great write up on the repair
