Stock TRD OR 18in. rim tire PSI
Discussion in 'Wheels & Tires' started by 8MINT8, Feb 6, 2018.
  1. Feb 6, 2018 at 12:26 PM
    8MINT8
    8MINT8 [OP] #NotBetty
    Lost
    2018 Unicorn TRD
    Hi. Taking a little consensus from people with the TRD OR package with stock Michelin on 18 rims. My door jamb says 32 front/33 rear. Truck was picked up brand new from dealership with 41 psi on all tires. Seems kinda high but truck drives great and smooth. What do you run your tires at? I was debating on wether to lower them to 36psi or not.
  2. Feb 6, 2018 at 12:51 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I have the 18" TRD wheels and run what the door sticker says. Some will tell you to set the pressure higher for better fuel mileage which is true in theory but the difference is probably negligible. The higher the pressure the rougher the ride.
    Bprose likes this.
  3. Feb 6, 2018 at 1:00 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    I run 3 to 5 psi higher than what’s on the door sticker... I can’t feel a Change in the ride... does it help with fuel mileage?..... meh...
  4. Feb 6, 2018 at 1:02 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    My sticker says the same thing, and the tires look kinda low at that setting. They are Firestone Destination. I bumped them up to 38 cold. Don’t notice any negatives in ride quality.
    Just make sure you don’t exceed the max pressure on the sidewall.
  5. Feb 6, 2018 at 3:11 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Ran my stock tires at 40-44 psi for a good year or so, and that let to me wearing down the middle tread a hell of a lot faster than I should’ve. I had 4-5/32 on the outside tread, and the middle was down to 2/32 when I replaced em. Loved how the truck rode with the higher psi, but if you’re wanting normal tread wear, I’d recommend running at the psi on the door or only slightly higher. Granted I still ran those tires from 67,000 miles to 110,000.
    Bprose likes this.
  6. Feb 6, 2018 at 4:20 PM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    I did the same thing
  7. Feb 6, 2018 at 4:22 PM
    Masshole
    New England
    Need to do the chalk test. Can avoid that problem.
  8. Feb 6, 2018 at 7:17 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    I run 44 psi on the stock steel 18” rims and the 255/70/18 tires. No issues and wear is good. At 30-33ish the tires look half flat and it rides more mushy. Especially when hauling stuff.
