Stock Tires Bad or Other Issue?
Discussion in 'Wheels & Tires' started by Jcmf52, Feb 14, 2020.
  1. Feb 14, 2020 at 2:05 PM
    Jcmf52
    Jcmf52 [OP] New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    So I bought the truck new, have 19k on it and the tires have worn quickly on the edges.
    is this just bad tires? Need alignment on brand new truck? Justification to the wife for sway bars all around? :kona:
    I do park in parking garage at work, so not sure if that could be contributing....
    Any isight would be helpful
  2. Feb 14, 2020 at 2:06 PM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    I think this is a bad alignment. How do the others tires look? Maybe they never rotated them.
  3. Feb 14, 2020 at 2:08 PM
    AZBoatHauler
    So.Arizona
    Yikes. All 4 look that way? What PSI are you running? Have they ever been rotated? Ever hit anything that would have knocked it out of alignment? I wouldn't ride around on that tire much longer.
  4. Feb 14, 2020 at 2:11 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Isn't that pattern typical of under-inflated tires?
    Medic343 likes this.
  5. Feb 14, 2020 at 2:24 PM
    Jcmf52
    Rob
    2018-1794 S/C
    All 4 look the same. Been at 35psi as recommended.
    never hit anything to knock out of alignment....
  6. Feb 14, 2020 at 2:27 PM
    AZBoatHauler
    So.Arizona
    Have you been using the Toyota Care service? Maybe Toyota will warranty them?
    It looks like it is just the outside edge - is the inside edge wearing normal?
  7. Feb 14, 2020 at 3:59 PM
    Jcmf52
    Rob
    2018-1794 S/C
    I have been using Toyota care (rotations def being done).
    the inside is not as badly worn as outside edge.
    Toyota does bot warranty them, you have to work with manufacturer at specific locations (listed in tire warranty book)
  8. Feb 14, 2020 at 4:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Do you drive mostly city? My wife and i drive maybe 10% freeway and our outside edges always wear faster from all our turns in the city
  9. Feb 14, 2020 at 4:04 PM
    Jcmf52
    Rob
    2018-1794 S/C
    I do drive mostly city...
  10. Feb 14, 2020 at 4:05 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The stock tires are very weak in the sidewall. With our heavy trucks that shoulder area of the tire takes a beating in turns
  11. Feb 14, 2020 at 4:08 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Tires look pretty well shot all the way across but the wear difference screams alignment issue. Solution is 4 new tires and a good alignment.....very soon. Don’t accept an alignment if they can’t show you wear it was out of spec and causing that wear. You’ll be back in the same place in 20k.
    YardBird and JLS in WA like this.
  12. Feb 14, 2020 at 4:57 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    If you do lots of city driving and are routinely cranking all the way to wheel lock it wears the outside of your tires like this. That said, I agree there is an alignment issue as well. Doesn’t matter if you think you hit something or not. Tires don’t lie.
  13. Feb 14, 2020 at 5:04 PM
    Jcmf52
    Rob
    2018-1794 S/C
    New tires and an alignment it is!
    Now to do the research on what tires to get with no lift
    YardBird likes this.
  14. Feb 14, 2020 at 5:11 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    For what it’s worth mine will look like that ina. Few thousand more miles and I kept bringing the truck back and bitching about the alignment, namely the toe, and they never got it figured out. I’m hoping new tires, of higher quality, will solve the problem.
    jewsNbrews likes this.
  15. Feb 16, 2020 at 8:05 AM
    Jcmf52
    Rob
    2018-1794 S/C
    Ordered some Cooper AT3 XLTs and having them installed this week.
    So ready for better tires :yes:
  16. Feb 16, 2020 at 8:41 AM
    JLS in WA
    Go to a different alignment shop.
    Different tires won’t solve an alignment issue.
  17. Feb 16, 2020 at 8:45 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If tires are P rated, they are under rated for Tundra. Will wear faster.
  18. Feb 16, 2020 at 9:11 AM
    15whtrd
    15whtrd Mr. Blonde
    Those tires look pretty well worn all the way across. You’re almost down to the indicators. My truck was on the path to do that and I noticed it immediately. First thing I did was run more air pressure in the front tires. That helped. Then put a rear sway bar on only and they started wearing much more evenly. I wouldn’t rule out getting an alignment but these trucks tend to wallow in the corners.
    Trooper2 likes this.
  19. Feb 25, 2020 at 10:31 PM
    Jcmf52
    Rob
    2018-1794 S/C
    So, tire shop said that the stock tires have a weak sidewall edge. There is a Bridgestone Dueler Alenza+ which is same tire but much stronger sidewall edge. Irritated that Toyota would put such crappy tires on the Tundras
  20. Feb 25, 2020 at 11:54 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Crappy stereo, crappy tires.. just another reason for an upgrade :thumbsup: I think you’ll like those coopers
  21. Feb 26, 2020 at 3:09 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    The inner part of the tire looks OK. Since the just the outside is worn, it looks like too much positive camber. You will new tires, but I would align the truck. Otherwise you could ruin the new tires you buy.
    Take a pic from the front of the truck and put a level in it. My guess is the front tires will not be straight top to bottom.
  22. Feb 26, 2020 at 6:52 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    During the 3 or 4 times you had them rotated & balanced, did the dealership mention abnormal wear?
    FWC likes this.
  23. Feb 26, 2020 at 7:14 AM
    FWC
    FWC New Member
    Upstate NY
    2019 Tundra Black Platinum
    My 07 Tundra came with Bridgestones as well, don't remember which one but I only got 12k out of them. They do wear quickly and curious to see what these Alenzas get on my '19.
  24. Feb 26, 2020 at 7:33 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The tundra corners so much tighter with e rated tires. These trucks are far too heavy for p rated tires. Toyota uses them because they are very lightweight and get better mpg
  25. Feb 26, 2020 at 7:39 AM
    Cthulhu
    @Jcmf52 , you're not alone. See pic below...this is at 39,000 miles, shitty P-rated Alenzas. Getting a set of Toyo Open Country AT2's put on Saturday, with alignment. Was considering the Cooper Discoverers and Falken Wild Peaks, but the Toyos were on sale at $120 less per set than the Coopers and Falkens, and the Toyos have great tread wear reviews. I have a 2.5" spacer leveling kit in the front. Mixed opinions on whether or not a 2.5" spacer will severely affect alignment, so I am going to get it aligned anyways considering I'm moving from a 31.9" tire to a 34.1" tire (275/55 R20 to 275/65 R20). I'm interested in what the alignment measurements will be...if BARELY green, will probably invest in adjustable UCA's to get back to SOLIDLY green.
  26. Feb 26, 2020 at 8:01 AM
    Jcmf52
    Rob
    2018-1794 S/C
    the inside of the tire was worn similar to outside.... not just alignment issue
  27. Feb 26, 2020 at 8:02 AM
    Jcmf52
    Rob
    2018-1794 S/C
    dealer never once mentioned abnormal wear. Even took it to them a random time to patch one of the tires
  28. Feb 26, 2020 at 8:02 AM
    Jcmf52
    Rob
    2018-1794 S/C
    My guess is that they will not last much longer, as they are probably the same tire
    FWC[QUOTED] likes this.
  29. Feb 26, 2020 at 8:04 AM
    Rex Kramer
    Georgia
    A rear anti-roll bar and new & better tires may be all you need. Of course you will want a new alignment when the new tires are installed.
  30. Feb 26, 2020 at 9:50 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ive got 34k miles on the stock Michelin AT2 tires. They are at 5/32nds, not too far from the wear bars. They are also more worn on outside. Purchased the truck used so no idea if previous owner kept correct pressure or rotated them...they do however all have the same tread depth and wear.
    And those tires are rated for 60k miles.....I can't imagine how they would look if I tried to run them that long.
    In doing some research on replacement tires I have seen that other trucks- fords, dodge, etc also appear to quickly wear out stock or P rated tires...based on the posts in their forums.
    I think heavy trucks in general will wear out the outsides quick on P load tires. I have always moved to C load tire on past trucks, jeeps, 4runners with great results....with my Tundra, I will be moving to E load and go up one tire size.
