Stock shock length
Discussion in 'Suspension' started by canadianguy, Jan 8, 2018.
  1. Jan 8, 2018 at 10:45 AM
    canadianguy
    canadianguy [OP] New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Hi all, just wondering who out there has a stock bilstein rear shock laying around that they measure for me? I got a rear 1.5” block and will be adding a aad so need to get shocks 3” longer.
    Thanx.
  2. Jan 8, 2018 at 10:49 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    If nobody else does it sooner I’ll measure one up for you after work. It’ll be about 4pm pacific time
    NewImprovedRon likes this.
  3. Jan 8, 2018 at 10:58 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    i have mine in the garage and will measure when I get home
  4. Jan 8, 2018 at 11:07 AM
    canadianguy
    Kevin
    Perfect, thanks guys!
  5. Jan 8, 2018 at 3:27 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    From base of perch where bushings sit to center of bolt hole is 24 1/2”
  6. Jan 8, 2018 at 3:48 PM
    canadianguy
    Kevin
    Sweet deal. Thanx Bprose
  7. Mar 24, 2018 at 5:55 AM
    Stocktundra1
    Stocktundra1 New Member
    Hugo
    04 tundra 4x4
    All new stock suspesion
    Its not stock hieght .Did the same change then it made mine drive shitty and had to change a slew of parts went with kyb gas a just still shitty what to do ?
  8. Mar 24, 2018 at 6:15 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Stock shocks are not designed to be used with a rear lift even though some people use them. Since you are planning to lift it even more, consider going with OME rear shocks (Bilstein 5100 may be okay, but you are pushing their capability here). Here are some specs I read when I was researching on shocks several years ago. (I don't think their specs have changed)
    Stock replacement (Bilstein 4600) TRD shocks.
    Collapsed length: 14.98 in
    Extended length: 24.45 in
    Travel: 9.47 in
    Bilstein 5100 (listed for 0 - 2" lift)
    Collapsed length: 15.33 in
    Extended length: 24.8 in
    Travel: 9.5 in
    OME Nitrocharger (listed for 0 - 3 in)
    Collapsed length: 15.15"
    Extended length: 25.6 in
    Travel: 10.45 in
    Big J and Backslider like this.
