Stock jack height
Discussion in '2.5 Gen Tundras (2014-2021)' started by ForceV4, Jun 20, 2019.
  1. Jun 20, 2019 at 1:35 PM
    ForceV4
    ForceV4 [OP] Pull my finger
    Sacramento
    2018 DC TRD 4x4
    At the risk of looking like a complete putz, I ask of you guys/gals... Am I the only one who finds the stock jack to be too short? I've got a flat front tire and cannot lift the truck enough to remove the wheel. There certainly isn't enough room to stuff a replacement wheel with a fully inflated tire in there like this. It's all stock-no big tires, no lift. I'm generally a fairly competent person with an occasional DOH moment like most people. Maybe this is one of them.
    Now that I'm thinking about this, what are you using with 35" tires and lifts? A Hi Lift is great if you've got somewhere to use it. I don't have sliders or a bumper that could take that sort of lift. Lastly, how big of a tire will fit in the stock spare location?
  2. Jun 20, 2019 at 4:19 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    according to the manual the jack point for the front is on the frame behind the transmission cross member, is this where you tried to jack?
  3. Jun 20, 2019 at 4:27 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    No. You're not.
    The Mama Toyota, like so many OEM ones, is fully and completely inadequate. You need to keep a collection of shorter 2X6's in the back of the truck so that you can raise up "the ground" for jacking purposes. I find the stocker such a frustrating POS that I keep a 3 ton (or is it 6?) little hydraulic bottle jack in the bed too. Some 2X's and a little bottle jack makes it SO MUCH EASIER. With this set up you can easily jack right off of the frame.
    And now a word from my lawyer: YMMV.
  4. Jun 20, 2019 at 5:38 PM
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    Yes, I was. When that didn't work, I used the cross member itself. No joy. Now that it's all over with, I suppose the ground may not have been level. I don't recall anything out of the ordinary.
    TundraMcGov, good to know I hadn't lost my marbles. An inadequate jack is BS. People can get badly hurt stacking things to get the jack up high enough. Today, all I had at my disposal were rocks and deadfall.
