Stock 2019 TRD Sport Crewmax Owners, I need a measurement...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mike19, Apr 22, 2020.
  1. Apr 22, 2020 at 9:27 AM
    Mike19
    Mike19 [OP] New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Hi All,
    Can you measure the length from the bottom of your 20" wheel (not including tire) to the bottom of the fender well for all 4 tires? Thanks in advance!
  2. Apr 22, 2020 at 11:53 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I can do it this afternoon after work if someone hasn't beaten me to it by then. I have a 2020 but that's the only thing different.
    Measuring for height gain from your suspension?
  3. Apr 22, 2020 at 4:03 PM
    Mike19
    Chi town
    Yes. Thanks so much. There’s too much tire variation the you measure from the ground to the fender well.
  4. Apr 22, 2020 at 4:41 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    EDIT: I messed up. Passenger rear is 34 3/4 not 32 3/4. Updated below
    I measured from the rim (center bottom) and straight up to the fender. I’m not on a perfectly flat spot but from side to side it’s flat.
    Driver front: 32 3/4
    Passenger front: 33
    Driver rear: 35 1/4
    Passenger rear: 34 3/4
    I don’t see any pattern here honestly. 35 psi on all 4 tires. Only thing in the bed is a 2x6 and muck boots. Half tank of gas (38 gallon tank)
    hope this helps some!
  5. Apr 22, 2020 at 6:19 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You get the most accurate measurements from center of hub to bottom of fender. That measurement is the same across the board on stock non pro tundras.
  6. Apr 22, 2020 at 6:58 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I don’t disagree with that. But also nothing wrong with measuring from bottom of rim when knowing the same rim size is in question.
