Stock 05’ DC only 1/2” taller in rear...that normal?
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Oct 10, 2020.
  1. Oct 10, 2020 at 5:52 PM
    Motopilot
    Motopilot [OP] New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    So I have a stock 2005 DC sr5 4wd. I’m planning on lifting it just a little. So was measuring it and it’s only a half inch higher in the rear. Honestly not even noticeable. Was wondering is that normal?
  2. Oct 10, 2020 at 5:53 PM
    Motopilot
    Josh
    NC/FL
    Oh yeah forgot to disclose that it does have a leer topper on it but it’s not heavy at all
  3. Oct 10, 2020 at 7:20 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    post some pictures of the truck and also the front wheel well and coilover, maybe it has a spacer?
  4. Oct 10, 2020 at 7:46 PM
    Sunnier
    Sunny
    San Diego, CA
    Without knowing the official answer, I’ll weigh in with an opinion that that’s “normal” for 15 year old leaf springs + a Leer topper. When I bought my 2002 a couple years ago, there wasn’t much rake.
    bmf4069, FrenchToasty and Hbjeff like this.
  5. Oct 10, 2020 at 7:57 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    I missed the spacer on my 06 when I bought it, I was so occupied looking for rust
  6. Oct 11, 2020 at 6:41 AM
    Motopilot
    Josh
    NC/FL
    @seth419 doesn’t look like one to me but I’m very new to this stuff
    seth419 likes this.
  7. Oct 11, 2020 at 5:36 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I don't see a spacer there just the top hat.
  8. Oct 11, 2020 at 5:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Looks like a spacer to me, you can see the bolts running thru it at the front corner
  9. Oct 11, 2020 at 5:38 PM
    biebs96
    PA
    That looks like a spacer in there. Notice the gap around the bolts going from the spring assembly to the actual mount.
    FrenchToasty likes this.
  10. Oct 11, 2020 at 5:39 PM
    biebs96
    PA
    posting near identical response at almost exact time...
  11. Oct 11, 2020 at 5:41 PM
    artsr2002
    'Yonder
    Guess I missed that since that gap doesn't look like it lines up with the bolt coming out of the top. Guess it could be a spacer. :confused:
  12. Oct 11, 2020 at 5:43 PM
    biebs96
    PA
    only noticed it immediately because I ran a spacer exactly like it when I had my 05 DC
  13. Oct 11, 2020 at 5:44 PM
    artsr2002
    'Yonder
    I have a spacer too but mine is aluminum and not painted and thicker so it's stands out more. Lol
  14. Oct 11, 2020 at 6:20 PM
    Outbound
    Aaron
    Northern Alberta
    That control arm also looks more horizontal than normal too. Certainly looks like a spacer.
  15. Oct 11, 2020 at 6:25 PM
    Motopilot
    Josh
    NC/FL
    So the consensus is a lift via a puck or spacer...1” maybe? Ok was looking at my leaf springs but didn’t get a pic. They are virtually level if not slightly bowing down. Meaning the ends might be slightly lower than the center.
  16. Oct 11, 2020 at 6:30 PM
    Outbound
    Aaron
    Northern Alberta
    The leafs on my 05 are similar. I think that's a symptom of age. I'm planning to replace them and install Firestone air bags eventually.
  17. Oct 11, 2020 at 6:31 PM
    Motopilot
    Josh
    NC/FL
    Just trying to figure out what’s my best option for lift and tires. I’ve never lifted any of my trucks in the past. I’ll be mostly pavement pounding and driving on the beach. Might retrieve a deer out of a field or a farm road here and there.
  18. Oct 11, 2020 at 6:35 PM
    Outbound
    Aaron
    Northern Alberta
    I'm really happy with my Bilstein 5100 suspension.
  19. Oct 11, 2020 at 8:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I too am very happy with my billies and the OME taco springs. ride is amazing for a truck running E range tires.
    [​IMG][​IMG]
  20. Oct 12, 2020 at 4:42 AM
    Professional Hand Model
    Hand Protectors
    Same driving use here. I’m on Billy 5100’s all around. Front Shocks adjusted one notch up from the lowest setting. They are a great value. Excellent of street/highway. Excellent towing/hauling. Off-road at slow speed they are firm. Research progressive vs. digressive shocks.
  21. Oct 12, 2020 at 1:05 PM
    Motopilot
    Josh
    NC/FL
    Pulled the trigger on the Bilstein 5100’s (Adj) front and rear...new right and left oem lower ball joints...And new 285/75r16 MT tires. About to order Black Sportsman seat covers and just got my weathertech mats in.
  22. Oct 13, 2020 at 7:28 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I'm late coming back to the party, but definitely a spacer like others stated.
  23. Oct 13, 2020 at 12:39 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Just curious if you are going to do anything on the back end of the truck?
  24. Oct 13, 2020 at 12:48 PM
    Motopilot
    Josh
    NC/FL
    @rock climber I'm going to see how it looks...I’ve got a 1” block and a add a leaf in my Amazon cart. I’m leaning towards the leaf over the block.
  25. Oct 14, 2020 at 5:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I wouldn't even consider the block. I've heard too many bad things about them.
    Sunnier likes this.
