Still waiting for an correct answer...
Discussion in '2.5 Gen Tundras (2014-2021)' started by hagrid, Aug 8, 2022.
  1. Aug 8, 2022 at 6:23 AM
    hagrid
    hagrid [OP] The most diverse of Diversity Hires!
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What is the limiting mechanical factor necessitating the 5900rpm redline of the 5.7l iFarce engine?
    I think it's the non-captive cam followers. Change my mind. Do so concisely and accurately, plz.
    Black Wolf and Vizsla like this.
  2. Aug 8, 2022 at 6:26 AM
    NH 2018 Limited
    NH 2018 Limited New Member
    2018 Tundra Limited TRD Offroad
  3. Aug 8, 2022 at 6:42 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Hey @ViktorG figured you'd probably be one of the few on here who would know.
  4. Aug 8, 2022 at 6:49 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Mechanically? not sure. Programmatically? it is the tune. My redline is at about 6400 rpm with the DAP tune. I have had the tune for 5 years now with no issues. Although, I rarely drive at redline.... but I do occasionally. I am not sure what damage might be done if I was always driving the truck at redline, but so far, so good.
    Black Wolf and HulkSmurf14 like this.
  5. Aug 8, 2022 at 8:36 AM
    CTundraForMe
    CTundraForMe New Member
    I think it has to do with how quickly the valves can open and close (relating to springs?). At some point you have problems with pistons getting out of sync with valves which is a bad thing (tm).
  6. Aug 8, 2022 at 8:42 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Usually it would be valve float due to the lifters leaving the cam at high rpm's and not enough spring pressure BUT this is an overhead cam so highly unlikely spring pressures would be the limiting factor. My guess is performance degradation the further past max torque is what limited max RPM's.
    ViktorG and Roctane84 like this.
  7. Aug 8, 2022 at 8:50 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Now days everything is limited by programming. Turn up programming get more rpm's. Not necessarily more horsepower just rpms. Which comes back to cam design and head flow which need to work in sync with each other.
  8. Aug 8, 2022 at 8:52 AM
    Vizsla
    Vizsla 2 = 2.5
    Sorry, research has been inconclusive to date. Will continue testing with 6250rpm WOT shifts and report any findings.
  9. Aug 8, 2022 at 9:35 AM
    1UP
    1UP Truck Gang
  10. Aug 8, 2022 at 9:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    HellifIknow....I only hit 5k on a blue moon.
    I'm tuned to 6k tho. My MAF was hitting 5volts. 8 psi blower....
    I'm all stock intake.
    so maybe the limiting factor is the 3.5 inlet?
    1UP[QUOTED] likes this.
  11. Aug 8, 2022 at 9:45 AM
    I'm going to lob a softball and say the limiting factor is the transmission cooler....or lack thereof depending on year.
    :D
    MSU Tundra, Oey12, ATV25 and 12 others like this.
  12. Aug 8, 2022 at 9:45 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    LS3 and ColoradoTJ[QUOTED] like this.
  13. Aug 8, 2022 at 10:53 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    If anything it is the connecting rods. Connecting rods fail when you bring it up to redline and then remove the air (close the throttle). Now instead of the piston nearly always pushing down on the rod because your are compressing air or burning fuel you are flinging the piston up and down.
    Valve float is rarely a problem on a OHC with direct acting valves. It is is a problem on a pushrod engine with hydro lifters and rockers.
    My bet would be that this engine is capable of a lot more than 5,900 RPM but the engine really does not make any more power beyond that so they set the limit and let it be.
    Just my two cents.
  14. Aug 8, 2022 at 11:40 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    My exact thought.
  15. Aug 8, 2022 at 11:47 AM
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    Its not a boat engine, and not a race car, so why exactly is this important?
  16. Aug 8, 2022 at 12:31 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    I will respectfully disagree with you here. It is the 0 weight oil that is only good for gas mileage. If they used proper oil, it would redline at least 2,000 higher :)
    Sorry, just had to do it.......
  17. Aug 8, 2022 at 12:47 PM
    Retired...finally
    Remove those tow hooks and you gain a least 1,000 RPM. Oh and wind noise, rear wheels that part company, beds that hit cabs........:crapstorm:
    Cpl_Punishment and AZBoatHauler like this.
  18. Aug 8, 2022 at 1:12 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Higher probability of cam tower leak at higher RPMs due to increased vibration of the inferior, robot-installed grey gasketing material.
    Retired...finally likes this.
  19. Aug 8, 2022 at 1:14 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was going to say that but then it implies they knew in 2007 that they would eventually delete it, which makes me sad.
  20. Aug 9, 2022 at 3:46 AM
    Bammer
    Monroe, CT
    I think redline issue was trying to be corrected when Toyota switched from 0w20 to 0w16, desired results were not achieved unfortunately. Rumor has it that a 0W-29 weight is being tested with a 36,599 redline.
  21. Aug 9, 2022 at 4:02 AM
    blanchard7684
    blanchard7684 New Member
    is redline same in landcruiser?
  22. Aug 9, 2022 at 4:04 AM
    I'm certain it's the AIP limiter....
    Cody1060 and ColoradoTJ[QUOTED] like this.
  23. Aug 9, 2022 at 6:33 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I'd like to buy a vowel.
  24. Aug 11, 2022 at 2:12 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I believe the 5900 RPM limit from factory is due to the engine starting to lose power past that.
    I don't know what the actual mechanical limit is since I have not blown up a 3UR from over-speeding it (yet), but we have revved the bone stock engine to 7000 RPM on the dyno multiple times without failure.
    I personally do not suggest going much past 6500 RPM on the stock setup for longevity/safety reasons.
    On my race truck with a forged bottom end, high lift cams, titanium valves, retainers and upgraded springs I have hit 7300 RPM a few times with no issues, still using the stock hydraulic lash adjusters and stock rockers.
    kos221 and mverkaik like this.
