Stiff Moody Steering
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hoff, Jan 3, 2024.
  1. Jan 3, 2024 at 11:23 AM
    Hoff
    Hoff [OP] New Member
    2021 TRD OFF ROAD CREWMAX
    I currently own a 2021 TRD OFF ROAD all stock original everything. Truck has 18000 miles on it. From day one the steering felt stiff. Stiffer than my 2020 identical truck. The stiffness varies and comes and goes. Lately at times it gets really stiff almost like it’s locked up but only for a few seconds then goes back to normal. Steering never pulls to the left or right just stiffens. I checked steering column it seems well lubricated. Talked to multiple dealers they seem confused. Could it be a weak steering pump. Any thoughts.
  2. Jan 3, 2024 at 11:55 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I need to get my dyslexia looked at...here I thought this thread was about driving "hands-free"...
    coTony likes this.
  3. Jan 3, 2024 at 12:26 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    2021 had a recall for a leaking steering rack if I remember correctly. Has the dealer checked if your truck was affected?
    KNABORES likes this.
  4. Jan 3, 2024 at 12:31 PM
    Hoff
    My truck was the last off the 21s. Recall was never issued for my truck. I looked into it. And I don’t have any leaks.
  5. Jan 3, 2024 at 1:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Check the tire pressures also
    Saltyhero13 likes this.
  6. Jan 3, 2024 at 1:18 PM
    Hoff
    Tire pressures are good.
  7. Jan 4, 2024 at 10:31 AM
    luxury4play
    luxury4play New Member
    is it stiff while jacked up off the ground?
    Vr0ck likes this.
  8. Jan 4, 2024 at 12:11 PM
    Hoff
    I will check that shortly.
  9. Jan 4, 2024 at 12:31 PM
    Hoff
    I just jacked up the front. Steering turns easy and smooth no strange noises
  10. Jan 4, 2024 at 2:30 PM
    luxury4play
    id look into your PS pump. Dealer able to replicate the issue?
  11. Jan 4, 2024 at 2:39 PM
    Hoff
    I had discussions with two knowledgeable guys in service at different dealerships. Both mentioned possibility of weak steering pump. Since the truck has another year warranty left I’ll be patient with it.
  12. Jan 4, 2024 at 2:41 PM
    luxury4play
    i wouldn't be patient with it... if that pump decides to completely go, you might have an accident.
  13. Jan 4, 2024 at 2:44 PM
    Hoff
    You’re probably right.
  14. Jan 5, 2024 at 1:03 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Even though it's unlikely, the way it's stiff sometimes but not all the time makes me wonder if one of the u-joints on the steering intermediate shaft might be defective and binding up. Normally that's an old age thing when the rubber seals go though. I had one go out on the Tacoma at about 150k and needed to drown it in pb blaster for two weeks until a replacement could be put in, but what you described sounds similar to what it felt like on that truck. Did the dealer check it?
  15. Jan 5, 2024 at 8:56 AM
    Hoff
    I’ve talked to dealer service managers. I shall make an appointment soon.
