Sticker code for towing capacity chart
Discussion in 'Towing & Hauling' started by awq735, Apr 17, 2019.
  1. Apr 17, 2019 at 1:26 AM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    Can I figure out the code for the towing chart based on the body style and engine choice? Im getting ready to go look at a 2019 sr5, double cab, 6 1/2' bed with the 5.7 flex fuel engine. It has the larger fuel tank (38 gal), 4x4, and the sport package.
    I'm trying to figure out the max tow rating before I go look at it this Saturday. I have the vin if that helps.
  2. Apr 17, 2019 at 2:20 AM
    trbyrne1
    trbyrne1 New Member
    Tom
    Boise, Idaho
    2018 SR5 Inferno
    Tundra tailgate letters, tinted windows, window vents, level 8 wheels, Bilstein all around.
    I have the 2018 version of your truck my owners manual says and it was advertised as such a towing capacity of 9800lb. I will be hooking my 5400 dry weight travel trailer to my truck next month for the first time. I did put Firestone Airbags (something I've wanted to do on all my trucks) on my Tundra. The engine sticker on the inside of drivers door should give you a code to compare to the owners manual.
    Good Luck, so far I love my Tundra compared to the Ram & Ford I used to have.
  3. Apr 17, 2019 at 2:26 AM
    awq735
    Anthony
    Ohio
    Thanks for the quick reply. I was thinking the 9800 lbs. Was what it was going to be... I'll be sure to look for the code when I get to the dealership. I made the mistake of not knowing much of anything about my current truck when I bought it(2010 F150).
    Did you go with the manual fill airbags or the onboard compressor system?
  4. Apr 17, 2019 at 7:40 AM
    Jesusquintana
    Jesusquintana New Member
    Roger
    Central Texas
    2018 Crewmax 4x4
    What are you going to tow? You will want to check out the max payload sticker on the inside of the door as well.
  5. Apr 17, 2019 at 7:53 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Don't forget tires. P rated won't handle like E rated
  6. Apr 17, 2019 at 8:09 AM
    awq735
    Anthony
    Ohio
    24 foot camper, 4700 lbs dry and 7300 fully loaded
  7. Apr 17, 2019 at 9:19 AM
    Jesusquintana
    Roger
    Central Texas
    2018 Crewmax 4x4
    http://www.keepyourdaydream.com/payload/
    Watch the video and use the GVWR and Payload Calc spreadsheet here to input your numbers. You should fine with the DC and I don't see why you would need airbags unless you are maxing out the 7300 or hauling heavy payload in the bed of truck
  8. Apr 18, 2019 at 6:17 PM
    Mks99
    Mks99 New Member
    2019 Barcelona Red Platinum
    let me take you off topic a bit.... Why are you looking at the FFV engine?? Big downside here is that the FFV has a recommended oil change of 5000 miles instead of 10 for the base engine. Not a huge cost for a low mileage vehicle but if you are driving a lot that could end up being another $100-200 a year. Unless you are going to save that somehow in fuel costs ( I don't see how) you might see a bit of savings by finding something besides the FFV.
    I think the tow rating is the same but you will get less mpg out of the FFV.
  9. Apr 19, 2019 at 12:52 AM
    awq735
    Anthony
    Ohio
    It's not that I'm particularly looking for a truck with a flex fuel engine in it, but that's what I keep finding. I have no intention on running e85 in the truck due to the lack of availability in the area and the lower mpg's. I was used to changing my oil at 5k with my current truck so that wouldn't be a big deal, however I thought I read that the recommended oil changeninterval for normal driving was 7500 but I could be wrong.
