Stereo help
Discussion in 'Audio & Video' started by Stanger, Feb 10, 2018.
  1. Feb 10, 2018 at 10:45 AM
    Stanger
    Stanger [OP] New Member
    Luke
    2014 Tundra CrewMax
    TRD exhaust and intake
    Gentlemen, I am having an issue with my stereo which started right after I replaced the battery. The left speakers seemed delayed in comparision to the right speakers. When I put the fade all the way to the left I get nothing out of the speakers but when the fade is neutral I get volume from the left speakers. Any idea where to start troubleshooting? I have already disconnected the battery for 10min then reconnected it with no luck.
  2. Feb 10, 2018 at 11:10 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Maybe dumb questions: is it a stock stereo? Did you try to put the balance to the right(if aftermarket maybe they were hooked up backwards). Where they time corrected before with either a dsp or headunit(again aftermarket) if it’s all stock :notsure:.
  3. Feb 10, 2018 at 11:18 AM
    Stanger
    Luke
    2014 Tundra CrewMax
    Stock unit.
    Everything worked fine till I changed the battery. Im not sure if there is a specific board for this application or not as the only thing I can think of is that maybe I blew something when I installed the new battery
  4. Feb 10, 2018 at 11:35 AM
    Juanjoolio007
    Oregon
    Hopefully you didn’t. I know the head units can do some weird things. Mine one day decided that it wanted to recalibrate the screen so all the touchscreen functions were one line higher. So if you have radio presets up and push the third one down you would get the second one. You could never select anything on the top row. It ended up getting changed under warranty. Good luck though with yours.
  5. Feb 10, 2018 at 2:29 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Did you reboot the radio?
    While the radio is off hold down the power button and it will reboot the radio.
    Try that, let me know if that works.
    Black Wolf likes this.
  6. Feb 11, 2018 at 7:26 AM
    Stanger
    Luke
    2014 Tundra CrewMax
    Just tried that with no luck. The radio did reboot but the sound is the same
  7. Feb 11, 2018 at 8:43 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Try disconnecting the battery for a few minutes then plug it back in, sometimes that fixes electronics “farts”
  8. Feb 11, 2018 at 9:45 AM
    Stanger
    Luke
    2014 Tundra CrewMax
    Tried that as well with no luck.
