Steps From Go Rhino
Discussion in '2.5 Gen Tundras (2014-2021)' started by mlucas555, Apr 19, 2018.
  1. Apr 19, 2018 at 5:41 AM
    mlucas555
    mlucas555 [OP] New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I have been looking at these steps from Go Rhino. They are a double step. Only draw back is that one website says they only have a 250lb rating, but the other websites don’t list a weight rating. I’m a big guy and just worried that they won’t hold up. Has anyone used these or something similar to them. I like the double step, as I’m getting ready to put a lift on my truck and my mother-in-law will need the extra step to get in. Thanks!
  2. Apr 19, 2018 at 6:15 AM
    Mootball
    Mootball New Member
    ‘16 TRD Crew Max
    None yet but plenty to come.
    In my experience if you are getting steps for your mother in law, the steps you have shown are not the most practical for getting out, they get very slippery and the lower step being small they have to make sure they hit that step and depending their age and mobility could be hard. Most steps have a rating of 250-300#, just my 2 cents. Go Rhino does offer good strong product though!
  3. Apr 19, 2018 at 6:25 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Was thinking the same about practicality. My N-Fabs are not the easiest to use and sometimes slick when wet.
  4. Apr 19, 2018 at 7:29 AM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Thanks guys! I will look at something else that is just a single step that I like and carry a small step ladder for her to use. She is ok with the steps that I have now, but when I put the lift on she will not be able to use them. I want to replace them as they are starting to rust and I don't like the look of them that much. They were on the truck when I got it used.
  5. Apr 19, 2018 at 7:31 AM
    Mootball
    Mootball New Member
    ‘16 TRD Crew Max
    Try these - those step you listed were steel too. These are composite (boards are) mount kit is still steel
  6. Apr 19, 2018 at 8:09 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I agree with Mootball. Although I would prefer no bars or ICI Magnum RT, using something like GR RB20's and whoever needs help can plant their steps anywhere along its length.
    I have the OEM ones, I don't like that they're plastic but they have a lip around the edge that prevents slipping. When my kids are older, I'm removing it, or not getting them on the next truck.
    mlucas555[OP] likes this.
  7. Apr 19, 2018 at 8:25 AM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    I have looked at the RB20's. I like those. Do you know if they have a weight limit, I could not find one for them. I also saw that they have an option for a second step for them.
  8. Apr 19, 2018 at 8:50 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Good question, you might have to call the company.
    Weird, I can't even find my own OEM boards when I google. Shopping for full length boards, I saw reviews that some started to sag, another reason I got the dealer to put OEM's so I could go back if that happened. I think GoRhino's are pretty solid though, and I like the look of the RB20's better than mine, same here:
    https://www.youtube.com/watch?v=bTCPKn9moxo
  9. Apr 23, 2018 at 4:16 AM
    Ks_SR5
    Ks_SR5 New Member
    2017 CM SR5
    I’ve been considering these once my lift is on. They are also from gorhino. They are the raptor style ones.
  10. Apr 23, 2018 at 4:55 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Those are nice. Last night I realized from another thread the RB20's are tapered, wider at the front. I wonder if RB10's are consistent width all the way down (someone said they were).
  11. Apr 23, 2018 at 10:44 AM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    I think the RB10's are consistent. There is a guy in the 3rd gen build thread, I think Vendetta2K or something like that, I know he has them and you can ask him?
