steering wheel wobble after tire rotation
Discussion in 'Wheels & Tires' started by Tun-D, Jun 5, 2019.
  1. Jun 5, 2019 at 1:47 PM
    Tun-D
    Tun-D [OP] New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I have a 2019 CM TRD Sport that I swapped the tires and wheels out with TRD OR wheels 275/70R18 tires about 900 miles into it. I just had my first 5-6K service done at a local dealer where I think they just rotate the tires. I swear I'm feeling a slight wobble in the steering wheel after the tire rotation. I had the 6112 shocks installed shortly after the tires and wheels and had an alignment done at that time as well. Everything has been super smooth until now. Has anyone ever experienced anything like this after a tire rotation? It's not too bad, but it's there and I don't want to wear some parts out because it's not all balanced or aligned properly now. Not sure if I should call the dealer or the tire shop that did all the work.
  2. Jun 5, 2019 at 1:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    One of your front wheels are out of balance. Probably didn't feel it when they were mounted in the rear.
  3. Jun 5, 2019 at 1:55 PM
    Tun-D
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Thanks Joonbug. Makes sense. I'm guessing my tire shop can recheck/balance pretty easily so I'll probably just stop by there this week.
    joonbug[QUOTED] likes this.
  4. Jun 12, 2019 at 5:56 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    got same problem after I mounted new rims. Very little wobble, couldn't really tell but after my last rotation, I think I have a bad rim. This is a second set of tires and still wobble. Pretty severe right now. New rotors and pads this weekend and will rotate tires to isolate problem rim.
  5. Jun 12, 2019 at 6:04 PM
    Tun-D
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I took the truck to the tire shop the next day and they rebalanced the wheels and said they were a little off. No wobble now.
    Pudge and myt1 like this.
  6. Jun 12, 2019 at 6:13 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Another shameless plug for Discount Tire.
    When they rotate your tires, for free, they also balance the tires.
  7. Jun 15, 2019 at 1:58 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    gonna use a different shop. When I had my stock tires mounted on new rims a little wobble. new tires installed by same shop and still wobble. rotated tires and much more severe wobble.
  8. Jun 16, 2019 at 12:08 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    fixed my wobble today with new rotors all around and rotate front to back. One tire up front had no balance weights at all. Guessing mechanic missed one being in a hurry. On the back can't hardly tell. But atlas I narrowed it down. and got new brakes. ( didn't need, but wanted)
  9. Jun 16, 2019 at 12:50 PM
    MtMan6698
    MtMan6698 New Member
    Wayne
    Florida Panhandle
    2003 Tundra Limited TRD
    On-going problem... needed two front tires when I got the truck back in March. I was in the process of doing other stuff(trying to recover from Michael)to it so I just got a couple of cheap tires($100ea mounted & balanced+tax of course). When I drove away, I heard a bang like a rock hitting the inside of the front fender. Had some wobble but thought it would settle and needed to get some other things done so ignored it. Then it occurred to me it might have been a weight that hit the fender. Eventually took it to a friend with a balance machine and we did the left front; the one I suspected. Drove some more and still had the shakes. Finally got back to my buddy again and we balanced the other one(RF). This is two months later. While balancing the tire we both saw something weird, but obvious; the tire is out of round. Would not suspected such a thing but it was pretty obvious. Had one of those ah-chit moments 'cause now it's too late to take the tires back(past 30 days). Sooo, put them on the back and it is better but not great. The tires were actually made in Thailand but so are some of the name brands, I am finding out.
