Steering wheel Vibration
Discussion in 'Wheels & Tires' started by VA10, Apr 12, 2017.
  1. Apr 12, 2017 at 7:56 AM
    VA10
    VA10 [OP] New Member
    2020 Tundra Limited TRD Off-Road
    About 3 weeks ago I noticed while driving at 65mph + my steering wheel has tight patterned vibration - more like a shimmy. Once the steering wheel starts to shake it will not go away until after I slow down to 50mph or lower.
    The truck has 27k miles on it. The steering wheel feels exactly as it did from the dealer. Firm with proper steering responses (not indications of loose parts). There is not enough of a vibration to make me want to pull over. however, it is enough to visually see my hand shimmy.
    note*
    Stock wheels and tires.
    The truck has no suspension/lift mods.
    Has anyone experienced this? Any thoughts?
  2. Apr 12, 2017 at 8:00 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes. Its the tires wearing. Do a rotate and balance to see if it goes away.
    040Tundra likes this.
  3. Apr 12, 2017 at 8:02 AM
    VA10
    This is my first thought. I just had them rotated approx 2k miles ago.....I'll go ahead and do it and see what happens.
    thank you for the input.
  4. Apr 12, 2017 at 8:05 AM
    May need to be road force balanced
  5. Apr 12, 2017 at 2:26 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Why are you guys so damn smart? Let us insignificant people have a chance to answer on some of the low hanging fruit...(jk) lol!
  6. Apr 12, 2017 at 4:43 PM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    Could need new wheel balance. my truck had UN even wear on the outside of the tires dealer did quick check for alignment and said it was in specs at 5000 miles. went back at 10000 miles and told them to do the wheel alignment and sure enough it was out of alignment the quick alignment test they have is BS
