Steering Wheel STILL Shakes when braking
Discussion in '2nd Gen Tundras (2007-2013)' started by Huntduc2, Apr 6, 2020.
  1. Apr 6, 2020 at 2:08 PM
    Huntduc2
    Huntduc2 [OP] New Member
    SteveC
    2010 Platinum going strong at 340K miles
    LED's all around, TRD Sway bar, Bed Rug, 3m Film paint protection, Camper shell w/lighting
    2010 Tundra 4WD Platinum -- I've replaced the front pads and rotors. I've replaced the rear pads.
    I still get a significant shaking in the steering wheel when putting on the brakes.
    Bad Caliper/Bad piston in the caliper? Front bearing issue? It's driving me crazy!
    Appreciate the help.....
  2. Apr 6, 2020 at 2:30 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    I had the same problem with my 08.
    Changed the front rotors and pads but only the pads in the rear.
    Ended up being the rear rotors.
    :spending:
  3. Apr 6, 2020 at 2:34 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You would of felt a bad piston when you put the pistons in to install the new pads, common thing ive seen is people
    Not cleaning the hub up before they install the new rotors.
  4. Apr 6, 2020 at 2:37 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Worn steering rack bushings?
  5. Apr 6, 2020 at 5:14 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I had similar issues, there is a TSB reference this issue, but I dont remember what years are covered..
    My issue involved losing lugs on the passenger side, because the shacking would get pretty bad... I replaced both front rotors, pads and all 5 studs and lugs on the passenger side and 3 out of the 5 snapped off on tire removal and the other 2 had damaged threads which wouldn't allow the wheel to sit snug.
  6. Apr 6, 2020 at 7:55 PM
    Huntduc2
    SteveC
    Ok — not cleaning the hub and possibly having something that made the rotor not seat properly is easy enough to check out.
    I struggle to understand how rear rotors can result in a steering wheel shake but I’ve seen others post the same. Just not logical to me, but can appreciate the feedback.
    I just replaced the a-arm bushings on my Ranger due to “wiggle” when grabbing the tire when jacked up. I’ve read that a bad bearing will make the “woo woo” sound with the Tundra but not affect the shaking of the wheel — dunno.
    I haven’t looked into the steering rack bushings and will check those out.
    Thanks for the feedback
    JimboSlice413 likes this.
  7. Apr 6, 2020 at 8:18 PM
    BigArt
    BigArt New Member
    I took my truck to my local mechanic. He's in his 30's and runs the shop.
    He had his dad take it for a test drive. (he's like 65) he came back and immediately said it was the rear rotors. said the rear will shimmy and make you think it's coming from the steering or front end.
    once they change them it took care of he problem.
  8. Apr 6, 2020 at 10:15 PM
    empty_lord
    05 rollover special
    The rears can indeed be bad enough to shake the wheel. Mostly because of the frame flex on the tundras.
  9. Apr 6, 2020 at 10:59 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Best just do front and back all at once.
  10. Apr 7, 2020 at 4:39 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    You should always replace rotors with pads these days, it's cheap enough, and exactly, cheap ....rotors are not like they were back in the day. The days of pad slappin and turning rotors are over. Replace your rears and get back to use. One lazy piston in the caliper is another thought. Key words, "shakes when braking" so not related to the brakes would be worn tie rods, rack bushings, ball joints or control arm bushings. Simple jack the front tires up a little, set on jack stands, and do a wiggle test on the tires. Wiggle different ways, hands top and bottom, side to side, crisscross, and see what's loose if anything. Dirty hubs, and that would have to be like build up of rust dirty, would cause a unbalanced tire feeling while driving, not a shake when braking.
  11. Apr 7, 2020 at 5:02 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I put cheap ass autuzone pads and rotors on once that were out of round......had to go back and get more rotors....no problems since....this is on 04 tacoma.
  12. Apr 7, 2020 at 5:12 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Well I didn't say go that cheap. If I go cheap, Centric has always been ok, and Raybestos not bad for the price. You want better, than you pay more.
