Steering Wheel Squeak
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, May 18, 2021.
  1. May 18, 2021 at 10:31 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Hi folks, my steering wheel, or some part behind it, occasionally squeaks when being turned. It's not a groan, not a grinding sound, it's definitely what I would describe as a faint squeaking noise. But definitely noticeable. It doesn't seem to be coming from the suspension as far as I can tell (opening the window while turning wheel, the sound still comes from inside the cab around the steering wheel while I can't hear anything from outside the window).
    Any suggestions on what is causing the squeaking? I searched the forum and couldn't find anything. Thanks.
  2. May 18, 2021 at 11:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  3. May 18, 2021 at 12:52 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    This seems to be a commonality with Toyotas. That seal where the steering shaft goes through the fire wall tends to get dry and make noise. I had an RX300 that made noise, so about twice a year I’d spray silicone down around the seal and it would quiet it down.
    My LS430 is in the same boat and my sister’s 2012 Camry as well…
    I’d start there..
  4. May 18, 2021 at 2:25 PM
    NWPirate
    Zach
    WA
    Yep, all the above is correct. We had the squeak when turning every time.
    Was expecting to replace the seal but it was in good condition, just dry.
    Silicone spray and it's been smooth and quiet since.
    N84434 and DarkMint[OP] like this.
  5. May 18, 2021 at 2:29 PM
    DarkMint
    Ben
    Awesome thank you all so much. I swear this forum is amazing.
    bmf4069, N84434, NWPirate and 2 others like this.
  6. May 18, 2021 at 7:42 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I would agree. :cool:
    NWPirate likes this.
