Steering Wheel Radio Controls
Discussion in 'Suspension' started by Scooter916, Jun 4, 2021.
  1. Jun 4, 2021 at 9:58 AM
    Scooter916
    Scooter916 [OP] New Member
    Nathan
    08 5.7l CrewMax SR5 2wd,
    custom shift knob, Hooke Road front and rear bumpers, 12v Solutions Remote Start
    Couldn't finds anything via search so sorry if this has been asked already,
    I have a 2008 SR5 Crewmax and I am really missing the steering wheel radio controls from my old cars, do you guys know if the radio has a wire harness pre-wired for the steering wheel with radio buttons? Is it possible if I were to find a steering wheel off a salvage with the buttons would it be a somewhat easy swap?
    Ruby2 Tundra likes this.
  2. Jul 18, 2021 at 6:55 PM
    camillethetoy
    camillethetoy New Member
    jeremy
    08 DC 4x4
    2/1 Eibach Coilovers and 1" block
    Figure it out? I'm in the same boat.. :)
  3. Jul 19, 2021 at 8:58 AM
    Scooter916
    Nathan
    I haven't been able to dig up ant info yet. and haven't really felt like going out and pulling my steering wheel off
  4. Jul 19, 2021 at 9:02 AM
    camillethetoy
    jeremy
    08 DC 4x4
    All good, I did some research last night, it’s possible I believe with the right amount of homework
  5. Jul 22, 2021 at 8:10 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I think the answer is it "might" be prewiried. My single cab SR5 was not but depending on your trim level yours might be.
    My truck is a 2007 but It has a 2018 steering wheel and I wired in all of the radio and instrument cluster controls. I physically had to add the wiring into my truck however. The only thing prewired in my connector was the cruise control signal wire to the ecu and the horn. I added in wiring to power illumination (lights on steering wheel buttons) and wires for signals to the radio and cluster.
    Ruby2 Tundra and camillethetoy like this.
  6. Jul 22, 2021 at 8:17 AM
    Scooter916
    Nathan
    Thank you, I have an 08 SR5 Crewmax. I might just pull the stringing wheel one of these days to check. It wouldnt hurt to pull it off so I have an idea on how it will come off if I find ibe at a pick-n-pull type salvage yard
  7. Jul 22, 2021 at 8:32 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    This should help: The steering wheel controls plug into connectors Z2 and Z3 on the front on the spiral cable.
    On the inside they come on the back of the spiral cable on the J45 connector.
    Z2 has the horn and cruise control signal, ground
    Z3 has the steering pad, Phone control and Radio control.
    Your steering wheel from the salvage yard will have all the buttons and wiring for the Z2,Z3 connector. You just have to plug it into your truck on the front side of the spiral cable.
    Where you might have to add wires in the J45 connector that takes the signal from the back of the spiral cable and sends it to the radio or cluster. I added wires on pins 4,5,6,12
  8. Aug 9, 2021 at 5:23 AM
    Revned911
    Revned911 Denver
    Denver
    Missouri
    08 Tundra TRD, 72 FJ40
    At present, none. Planned: leveling kit, 33s, android head unit, 360 degree view cera's, front and rear dashcam, android head unit, front/rear bumpers, multifunction steering wheel, secret savings account.
    I did this on a mini Cooper to add mfsw and cruise control to a vehicle that did not have either of those things stock. Cruise control wasn't even an option for that trim car! Dumb..
    I had to replace the wheel AND the switchbox or blinker box (or whatever it is called, my brain is mush these days) AMD the wheel.
    This is exactly the thread I was hoping to find, as there no mfsw on my 08 TRD tundra. Thank you! Will update with success is I have any.
  9. Aug 9, 2021 at 6:33 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    My '07 DC TRD was pre-wired but without any controls. I swapped in a leather wrapped Sequoia steering wheel and the audio buttons work great. I considered going auto climate control, but for now those steering wheel buttons are extra.
  10. Aug 12, 2021 at 6:40 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    Jeff_5_7 how hard was it to switch to a 2018 steering wheel? I know a lot of people on here have asked if the 3rd gen steering wheel will swap to the 2nd. All I've ever seen is that it does not. I would be interested in doing this, since I hate my 2007 steering wheel.
    Ruby2 Tundra and Jeff_5_7 like this.
  11. Aug 12, 2021 at 6:50 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    My truck is a 2007 with a 2015 dash and a 2018+ steering wheel. The steering column is the 2007 one and was not changed.
    This photo shows it will the 2007 carpet and seats still installed. The 2018 steering wheel was a direct replacement.
    Unhook your battery, remove your steering wheel airbag and there is one large nut in the center holding the wheel on. After it is removed you need a puller to pull the old wheel off and then the 2018+ wheel slides right back into place. You will need a newer style air bag as they are not the same.
    As I mentioned above I had to add wiring for the steering wheel controls and lights on the buttons. You can add the newer style wheel and just have the buttons not hooked up
  12. Aug 12, 2021 at 9:07 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    Nice. I think I might do this. Only controls I care about are cruise control and stereo. Looks clean. I remember reading about that 3rd gen gauge cluster install. Looks nice. If I come across another 3rd gen in the junk yard I might just try and swap some stuff out.
  13. Oct 20, 2021 at 9:52 AM
    matt_hew68
    matt_hew68 matt_hew68
    Matthew
    Louisiana
    2011 White Toyota Tundra Crewmax 4x4
    victory 4x4 ditch light brackets cali raised side shooter led pods nilight 41 inch slim light bar Husky floor mats rago fab hidden bumper light bar mount nilight flood light pods in rear bumper ch4x4 factory push style switches coverking kryptek seat covers JBL GTO 609C front speakers skar audio rear door speakers and tweeters in dash dual 10 sundown SLD subs in fox box sundown SIA 1250 amp kobalt toolbox custom made stickers on back window LED fog lights Ceramic tint on all windows TRD pro fox suspension paracord wrapped grab handles Hikari 18,000 lumen Led headlights OPT-7 aurora interior led lighting Rock lights icon rebounds 18x9 +25 BFG Ko2 275/70r18
    So theoretically, if I had steering wheel controls in my 2011 and swapped the newer sequoia steering wheel, my volume, phone, and other controls should work?
  14. Jun 10, 2024 at 3:07 AM
    Ruby2 Tundra
    Ruby2 Tundra New Member
    Andria
    2007 Toyota Tundra Limited crewmax v8 5.7l
    Hi Kids! I've recently just purchased a 2007 Toyota Tundra Limited SR5 Crewmax pickup to replace my 2008 Toyota Tacoma Double Cab v6 6sp MT while I absolutely LOVE my Ruby Taco she became "asthmatic" when I tried pulling my 1986 Featherlite Aluminum horse trailer especially when going up hills I realized very quickly Ruby Taco just couldn't do it. Devastating as I absolutely LOVE driving her especially because she's a stick (and my 66 year old boyfriend can't drive stick, I KNOW!! Crazy right?).
    Ruby2 Tundra is a great truck however their is one thing that I'm going to miss about my Tacoma and thats the steering wheel radio/CD controls!! I am THRILLED to see it IS possible to swap steering to obtain those controls and I'm thrilled I found THIS website and this thread! Thank you for the information!
    Andria
  15. Jun 10, 2024 at 5:20 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
