Steering wheel play/ issues
Discussion in '1st Gen Tundras (2000-2006)' started by randyt3, Oct 8, 2021.
  1. Oct 8, 2021 at 12:43 PM
    randyt3
    randyt3 [OP] New Member
    2003 Toyota Tundra Sr5 T3 edition
    Hey everyone, recently over the past month I’ve started to see my alignment get worse, I have to keep the wheel crooked to the right to keep it straight and as I get past 60+ mph the steering wheel feels almost loose with a lot of dead space, as almost like I am swerving left and right throughout the lane. There is a grinding noise that comes from under when I turn the wheel stationary but nothing when I’m driving. Im guessing it’s the rack and pinion finally giving out, as I was advised previously that it was needed to be replaced eventually, but I saw no leaks under it and thought it was okay after putting in poly bushings. But after one night when I started the vehicle up and it was semi chilly outside the steering sounded like I had a supercharger in the engine and after that day I started thinking parts … I’m not really sure what I’m asking here but should there be any other parts I should check that could be causing it? Any help or advice would be great, I would appreciate it!
    Outbackrob likes this.
  2. Oct 8, 2021 at 7:58 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Get the front end off the ground and check your ball joints for play, tie rod ends and wheel bearings.
