Steering Wheel Controls Swappable?
Discussion in '2nd Gen Tundras (2007-2013)' started by Tallyn91, Dec 9, 2020.
  1. Dec 9, 2020 at 12:18 PM
    Tallyn91
    Tallyn91 [OP] New Member
    2014 Super White Tundra SR
    Have a 14 SR Tundra and have been looking at tacoma steering wheels cause I like the leather and want volume control. Trying to kill 2 birds with 1 stone but curious if anyone has swapped with a wheel that has a different button layout?
    Mine has no controls on the left and just the phone controls/ disp button on the right. This one is right up the street from me for a hell of a price and would love to swap it out but not sure that it would function correctly. Anyone tried this?
  2. Dec 9, 2020 at 12:30 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm pretty sure its a direct swap, minus the items you're not adding, so you'll have some hanging pig tails to tuck... I'd suggest remove your airbag and plug and play to see if stuff works. Obviously you will have to disconnect and reconnect your battery in the process... or compare the images you see, to your connectors just to verify, but I'm 90% sure it'll swap over.
  3. Dec 9, 2020 at 12:56 PM
    Tallyn91
    What do you mean the items I'm not adding? Just to clarify I currently ONLY have phone buttons and the disp button. Would be adding radio controls, etc. I know its no problem apparently when adding other tundra wheels but with these buttons in a completely different layout I was curious if it would work.
  4. Dec 9, 2020 at 12:57 PM
    blackdemon_tt
    I'm sure it would work, I must have misread your post.. my bad....
  5. Dec 9, 2020 at 1:00 PM
    Tallyn91
    Appreciate the quick replies! Guess I'll be giving them a call tomorrow. For 125 bucks it might be worth the risk
  6. Dec 9, 2020 at 1:04 PM
    Tallyn91
    Also, no idea how this ended up in 2nd gen forum. Look out mods, noob here
    blackdemon_tt likes this.
  7. Dec 11, 2020 at 6:55 PM
    14srAKH
    14srAKH New Member
    2014 tundra sr white
    Wheels, center console swap, tinted windows,
    Any update on this?
  8. Dec 12, 2020 at 12:32 PM
    Tallyn91
    Alright so got the wheel in last night and just tried installing the controls to see if they would even work. Nope, totally different connector. I guess they changed the connector between years. The white is what I have on my 14 and the black is what was on the tacoma wheel. Thankfully I can return it Monday and found a 4runner wheel that will definitely work for the same price. Just have to wait
    betotundra likes this.
  9. Dec 13, 2020 at 6:14 PM
    14srAKH
    14srAKH New Member
    But the connections were all there for the steering wheel controls?
  10. Dec 13, 2020 at 7:22 PM
    Tallyn91
    Not sure the question. The controls from both sides all go to one connector. Just happens the connectors were different so I'll have to get a wheel with the silver volume button where that black phone button was
  11. Dec 15, 2020 at 4:26 AM
    14srAKH
    14srAKH New Member
    Right. Sorry. I'm looking to do the same thing to my 2014 sr. Was trying to confirm that it was going to work. Plug and play.
  12. Dec 16, 2020 at 9:11 AM
    Tallyn91
    If you look at the original picture I posted, that wheel will not work. My new one should be in tomorrow and I'm 99% sure it will, plug and play. Has this button layout. Probably be Friday night when I get it on but I'll update when I do.
  13. Dec 16, 2020 at 10:27 AM
    14srAKH
    14srAKH New Member
    Sorry if my wording is confusing. I understood all of your posts but was just trying to figure out if the plug was behind the air bag or not. It sounds like toyota installed the harness but not the accessory.
  14. Dec 16, 2020 at 11:52 AM
    Tallyn91
    Yeah you have to take the airbag out to get to it. Plenty of write ups on here and it's super easy, just be sure to disconnect the battery first
  15. Dec 16, 2020 at 12:22 PM
    14srAKH
    14srAKH New Member
    Oh alright. I'll search better next time. Thank you.
  16. Dec 16, 2020 at 12:32 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    If not...
  17. Dec 18, 2020 at 4:43 PM
    Tallyn91
    Well. Got the controls in and no dice. The right side works (where I already had buttons) and on the left side the only thing that works is the audio mode button. No volume, no left right up down select.
    Whole thing illuminates and that one button works which makes me wonder if it's because I have the bottom of the line entune?
    Getting my new radio in Monday and was hoping to have it working for maestro.
    SOMEONE GIVE ME THEIR KNOWLEDGE
  18. Dec 18, 2020 at 5:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    When you plugged the controls into the factory harness, did you notice if there were wires/pins matching every position on both sides of the plug?
    obviously the controls have all the needed wires... the concern is whether your truck has the mating wires running to the back of the head unit (whether your factory heads unit will use them is a different issue).
    If all the wires are paired up and run to the back of the head unit, then you should have no issues with the maestro.
  19. Dec 18, 2020 at 5:09 PM
    Tallyn91
    So I haven't actually looked myself but did some research on the other forum and someone said the issue is there's two missing wires that have to be added from where the controls plug in to a harness on the back of the radio. Hopefully I can still flash the maestro all the same and then just add those wires at some other point because that does not sound like something I wanna do right now lol
  20. Dec 18, 2020 at 5:27 PM
    14srAKH
    14srAKH New Member
    Disappointing.
    I have already upgraded my stereo and should be getting the controls any day now.
    Do you have the link where read about the two wires?
  21. Dec 18, 2020 at 5:28 PM
    Tallyn91
    If anyone knows where connectors J139 and J45 are located that would also be a huge help.
  22. Dec 18, 2020 at 5:29 PM
    Tallyn91
    Don't have the link but screenshot it for future reference
  23. Dec 18, 2020 at 5:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I have the EWDs on my computer... I may be able to pull it up later tonight and post up.
  24. Dec 18, 2020 at 5:40 PM
    Tallyn91
    That'd be awesome! Pretty sure J45 is behind the steering wheel, not sure if it's the one I plugged into or not. And I believe J139 is one of the radio plugs just not sure which
  25. Dec 18, 2020 at 9:33 PM
    RainMan_PNW
    Casey
    Clark County, WA
    J45 is the spiral cable on the steering wheel, and J139 is one of many that goes in the back of the NON-navigation head unit. Attached is the 2015 EWD for the Audio system in a truck that does not have the separate amp and does not have JBL. This will show all the wires that you need to run.
    Whizzit and pickeledpigsfeet like this.
  26. Dec 19, 2020 at 9:45 AM
    Tallyn91
    Ill have to find the spiral cable but should be able to figure out 139 by the number of pins. Hopefully lol it will have to wait until after the holidays but I'll try to get some pics when I do it for future reference to those that want to try it. For now I'm gonna try to flash the maestro as if I have the controls so I dont have to do a whole reflash later. Thanks for getting those connector pictures!
    Whizzit likes this.
  27. Dec 19, 2020 at 10:44 AM
    14srAKH
    14srAKH New Member
    I am waiting for the controls now. Should be here today or tomorrow. I would love to know exactly what you do to gain the left hand controls for volume and such.
    Appreciate current and future updates as I am trying to do this to my SR.
  28. Dec 19, 2020 at 10:48 AM
    Tallyn91
    No problem. And if you get yours hooked up and they all work let me know so I can drown in sorrow and send this shit back lol
  29. Dec 19, 2020 at 3:02 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Spiral cable is also known as the clock spring - its a module at the steering wheel/ column interface that allows the electrical connections to continue thru to the wheel controls. The J45 connector will come up from the steering column and plug into the stationary part of that module.
    if you check it, you need to confirm if it has wires running to the pin-outs for the audio controls in the 3, 4, 5, and 6 positions.
    Whizzit likes this.
  30. Dec 19, 2020 at 3:46 PM
    14srAKH
    14srAKH New Member
    Haha. I did upgrade my stereo to an updated entune suite stereo. So I am hoping that it does but not holding my breath. I'll let you guys know if it does though.
    Tallyn91[QUOTED][OP] likes this.
