Steering Wheel Controls Stopped Working
Discussion in '2nd Gen Tundras (2007-2013)' started by Lifeofbrian, Aug 7, 2019.
  1. Aug 7, 2019 at 12:22 PM
    Lifeofbrian
    Lifeofbrian [OP] New Member
    2010 Tundra 5.7 Rock Warrior
    TBD
    Hello all,
    Bought my Tundra a couple months ago, steering wheel controls for the stereo just stopped working. No lights off or other non-working things so I dont think its a fuse.
    Any ideas?
    Not much info on the web about this.
    Thanks,
  2. Aug 9, 2019 at 4:02 PM
    Apollothetundra
    Apollothetundra New Member
    Trevor
    07 Super White 5.7l V8 295,000
    Do any of the other controls work ?
  3. Aug 9, 2019 at 4:14 PM
    TheBeast The Beach
    is the horn working ? do you have aftermarket head unit ?
  4. Aug 9, 2019 at 5:22 PM
    15whtrd
    15whtrd Mr. Blonde
    My money is on the clock spring. That is the one problem I had with my truck. One day I realized my horn wasn’t working. I think everything else was working. From my understanding you can you lose control of everything on the steering wheel, or bits and pieces depending on how bad the clock spring is. Mine somehow bird nested itself. There is a write up here about how to replace it yourself.
    TheBeast and JohnLakeman like this.
  5. Aug 9, 2019 at 5:23 PM
    Apollothetundra
    Trevor
    That is what I was thinking as well . I had the same thing happen and it was the clockspring. When i replaced it , it fixed the probelm . Non of my controls worked.
    15whtrd[QUOTED] likes this.
  6. Aug 9, 2019 at 5:34 PM
    Lifeofbrian
    TBD
    Horn works. Only thing that quit was the stereo controls. Stock head unit.
  7. Aug 9, 2019 at 5:46 PM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t know how to give you a definitive answer but I wouldn’t rule out the clock spring. My stereo still worked but my horn didn’t. There is a ribbon of wires
  8. Aug 9, 2019 at 11:09 PM
    TheBeast The Beach
    same happened on my 2008 Nissan Pathfinder, first the stereo controls then the horn. clock spring. still need to fix it but I'm too busy working on the tundra..lol
    15whtrd and Lifeofbrian[OP] like this.
  9. Aug 10, 2019 at 9:27 PM
    Lifeofbrian
    TBD
    ill give the clock spring a shot.
    15whtrd likes this.
  10. Aug 10, 2019 at 9:31 PM
    15whtrd
    15whtrd Mr. Blonde
  11. Aug 10, 2019 at 9:41 PM
    TheBeast The Beach
    you might need to re-calibrate after though. dealership kinda work.
    Lifeofbrian[OP] likes this.
  12. Aug 10, 2019 at 10:07 PM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Should still be under warranty take it back
  13. Aug 11, 2019 at 9:13 AM
    Lifeofbrian
    TBD
    Recal the computer?
  14. Jul 14, 2021 at 6:15 AM
    maurzy01
    maurzy01 New Member
    My apologies brining up an old thread. If this has been resolved, what was the issue?
  15. Jul 14, 2021 at 8:33 AM
    Lifeofbrian
    TBD
    15whtrd likes this.
  16. Jul 14, 2021 at 10:49 AM
    maurzy01
    maurzy01 New Member
    Did the preset buttons on your actual stereo unit not work as well? I can’t press the XM button or radio button to swap sources. The only thing that works is the mode button on the steering wheel. Once I have swapped sources, non of the preset buttons I have configured work when trying to change the station. I have to manually turn the tube knob.
  17. Jul 14, 2021 at 10:55 AM
    Lifeofbrian
    TBD
    The stereo worked for me. It was just the steering wheel controls that stopped working. If your stereo unit controls are not working that might be something else. If it is a stock radio I would suggest getting an aftermarket option to replace it and see if that fixes it.
  18. Jul 27, 2021 at 9:44 AM
    maurzy01
    maurzy01 New Member
    FYI - I found the issue. The push to talk button was stuck in the depressed position on my steering wheel. This prevented my radio and related on controls on the steering wheel from working properly. Just a wiggle released the button and everything is functional again.
