steering shake over bumps
Discussion in '2.5 Gen Tundras (2014-2021)' started by cameratoaa, Jul 12, 2017.
  1. Jul 12, 2017 at 2:54 PM
    cameratoaa
    cameratoaa [OP] New Member
    New to the forums, and I just up sized from my '14 Taco to a CPO 2016 Limited DC and before I go back and have to complain to the dealer I bought it from I wanted to know if this was a common trend.
    Over bumps I get moderate to severe steering deviation. The wheel will turn on its own over bumps. Truck tracks straight on good roads just fine so I was thinking the alignment is not the issue. Stock wheels/tires everything.
  2. Jul 12, 2017 at 3:57 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    What is the psi on the tires?
  3. Jul 12, 2017 at 4:01 PM
    Bienvenidos de Tejas! Post pics of your ride
  4. Jul 12, 2017 at 4:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Don't rule out alignment, if the caster is off, it'll still drive straight but can have some bump steer.
    Law323, GNTundra, Bear and 1 other person like this.
  5. Jul 12, 2017 at 6:56 PM
    cameratoaa
    No pics as of yet but I will...tire pressure was checked and oil changed right before I bought it but I can confirm the pressure tomorrow...alignment wasnt checked as far as I know.
  6. Jul 14, 2017 at 11:17 AM
    cameratoaa
    Tire pressure is 33 all the way around. I'm due for oil in 3000 miles so ill probably just have the dealer check the alignment at that time.
  7. Jul 14, 2017 at 11:27 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    NASA--you have a problem! I've owned 4 Tundra's and 4 Tacoma's and have never had anything like what you're describing happen. Could you please provide the mileage and accident history. how about a picture of the front tires wear too.This screams suspension/steering wear or damage problem. I would crawl under there and have someone work the steering wheel back and forth while you're looking for slack in the steering box and/or components. The first thing I would look at is the steering box itself and make sure the bolts are tight.
  8. Jul 14, 2017 at 11:30 AM
    cameratoaa
    No accidents, 19K, bought it with 17K on it. OE 20" wheels/tires
  9. Jul 14, 2017 at 11:46 AM
    Cement Pro
    Stock
    Does your steering wheel line up the way it's supposed to when your driving in a straight line?
  10. Jul 14, 2017 at 12:56 PM
    cameratoaa
    Yep, but it sounds like this isnt common so Im thinking alignment and will get that checked when i go in for oil.
