Steering rack
Discussion in '2nd Gen Tundras (2007-2013)' started by spcbuzzard, Sep 19, 2019.
  1. Sep 19, 2019 at 10:37 PM
    spcbuzzard
    spcbuzzard [OP] New Member
    Dustin
    2011 Tundra 4.6L V8
    So took my 11 tundra in for routine maintenance and they told me that the steering rack needs to be replaced. I thought they were talking about the whole steering column as I’d never heard of a steering rack. Anyway they wanted $2,100 without labor. Seems pricey.
    I’m not useless under a hood, or in this case the whole truck, but I’m no mechanic either. After some research I’m gathering that this can be a rather involved fix 10+hours. I hesitant to get halfway in and realize I can’t do it properly. Any advice if I do try it out?
    Mountun Goat likes this.
  2. Sep 19, 2019 at 10:40 PM
    spcbuzzard
    Dustin
    2011 Tundra 4.6L V8
    Also I’ve checked and can’t find any power steering fluid leaking anywhere. The dealership said it was a little low but that it was leaking. I’ll check again in the morning and see what happens.
  3. Sep 20, 2019 at 5:00 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    known issue...is your truck lifted?
  4. Sep 20, 2019 at 5:15 PM
    spcbuzzard
    Dustin
    2011 Tundra 4.6L V8
    No.
  5. Sep 20, 2019 at 5:18 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Just out of curiosity, how does the steering feel? Is it working at all?
  6. Sep 20, 2019 at 5:43 PM
    spcbuzzard
    Dustin
    2011 Tundra 4.6L V8
    Feels fine. Slight vibration at high speeds 70+. Power steering pump makes a light squeal if I cut it all the way and hold it. For a 100,000 mile vehicle she’s in good shape.
    Mountun Goat[QUOTED] likes this.
  7. Sep 25, 2019 at 10:12 PM
    K1NJO
    K1NJO New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
    I just blew my steering rack on my 11 as well. Just ordered a replacement a few minutes ago. Cheapest oem I found was for $702. But agreed with @15Yota that $2100 without labor is ridiculous.
    Mountun Goat and dcsleeper408 like this.
  8. Sep 26, 2019 at 5:43 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    If it were me I wouldn’t even worry about until you notice a change. I have 298000 miles on my factory steering and it’s sounds exactly likes yours for the last 2 years of owning it. I did a steering fluid flush on it two weeks ago and am currently putting some more runtime on it. Then I will replace the fluid once again. It’s been a tank of fuel since the flush, and 80% of the pump whine at full lock is gone.
    MS22 and Mnorris1206 like this.
  9. Sep 26, 2019 at 5:54 PM
    timsp8
    NY
    On my 10 it was about $3k parts and labor. Once it goes, it goes. You’ll have to be towed. But its sealed so I dont see how they are diagnosing it unless you are leaking lots of fluid.
