Steering rack getting stiff
Discussion in '2.5 Gen Tundras (2014-2021)' started by hollywood d, Jun 28, 2018.
  1. Jun 28, 2018 at 6:50 AM
    hollywood d
    hollywood d [OP] New Member
    2014 SR5 Tundra
    I noticed about two weeks ago that the steering in the tundra was stiffer than normal at low speeds. Parking lot speeds. I don’t notice it on the highway.
    It’s become fairy stiff, almost like something is binding up or the power steering is going out. I know this was an issue with the 2nd gens. I’m just under 60k miles on my 2014.
    I do have the Bilstein 6100 leveling kit up front sand stock tire size. Anyone dealt with this on a 3rd gen? I wasn’t able to find much info on failures with 3rd gens.
  2. Jun 29, 2018 at 5:10 AM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    My 2016 just had the rack replaced under warranty. Steering felt fine however a noticeable ammount of grease was pushed out on the passenger side where the tie rod screws in.
  3. Jun 29, 2018 at 5:13 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    This happened to me with my 2010 4Runner at about the 70,000 mile mark. It got progressively worse at slow speeds until it almost felt at time like the power steering was failing. Turned out the truck needed a new steering shaft. Something about joints getting bound up. The fix was covered under my extended warranty. I asked the guys if I didn't have the warranty what it would have cost, they said in the neighborhood of $500-$600 to fix. So it wasn't cheap but also wouldn't have been catastrophically expensive. Anyway, sounds like you could be having a similar issue.
  4. Jun 29, 2018 at 6:57 AM
    hollywood d
    2014 SR5 Tundra
    I have the extended warranty thankfully. I’ll check for leaking grease and dry joints.
  5. Jun 29, 2018 at 7:23 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea was an issue with some years of 2nd gen but haven't seen an issue with the 2014+. Mine went out but it didnt get stiff before going out. Really just started hearing wierd noises from the pump and then boom i had no steering.
  6. Jul 14, 2020 at 12:41 PM
    zeidouni
    zeidouni New Member
    zeidan
    Tundra 2014
    What fixed your issue?
    My truck just turned 60,000 miles over Covid while I didn't drive it much. Steering was noticeably stiffer. I started by oiling the U joint like crazy, then a Power Steering Fluid flush, then a Power steering pump replacement. None fixed the issue. The stiffness starts after driving the truck for 20-30 minutes or when the fluid is hot in the system. I was told a steering rack replacement can be in the $1000s since it calls for 12-14 hours labor on the 3rd gen 2014+ models.
