Steering Rack Boots
Discussion in '1st Gen Tundras (2000-2006)' started by albru2, Dec 13, 2023.
  1. Dec 13, 2023 at 12:44 PM
    albru2
    albru2 [OP] Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    I just replaced the tie rods and boots on a 2002 AC 4WD and I feel like I'm missing something on the passenger side of the rack. The driver's side has a nice lip on the rack housing that the boot just barely fits over snugly. The passenger side has an indentation between the bracket and the notch with the blue paint but it's way smaller diameter than the boot and definitely doesn't fig snugly. Does anyone have any pics of this so I can see if I'm missing something? I can't tell from the parts diagram from Toyota.
  2. Dec 13, 2023 at 2:28 PM
    What part number did you get?
    They appear to be two diff't part nums for my '06: https://www.tundras.com/threads/corner-of-shame-oem-minus-or-plus.122591/page-3#post-3417021
    Here are the part numbers, both the boots and the large clamps are different part number left to right...: https://www.tundras.com/threads/corner-of-shame-oem-minus-or-plus.122591/page-2#post-3416561
  3. Dec 13, 2023 at 2:29 PM
  4. Dec 13, 2023 at 5:52 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    What Shifty said, the left and right side are different. The OEM boots aren't too terribly expensive for what you're getting. Don't bother using the OEM metal clamps if it's going to be a hassle to procure. Just use one of those high quality plastic zip tie that has a metal locking tab. More than likely it will seal MUCH better than the band clamp you're currently using in your pic. Of course the OEM Oetiker clamp is excellent, but it's not always feasible to order JUST one or two clamps from a dealer...especially when MSRP is $3.46, local dealer wants around $9 and change, and online dealers sell them for around $1.73.
    shifty` likes this.
  5. Dec 13, 2023 at 7:16 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Rock Auto doesn't specify right vs left on the bellows which is concerning. Maybe OEM is the way to go.
  6. Dec 13, 2023 at 7:18 PM
    And just like that I’m in fashion again for wanting to splurge on OEM :rofl:
  7. Dec 13, 2023 at 7:28 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Hey I'm normally OEM or Die. I just didn't think even Moog could fck up a rubber boot.
  8. Dec 13, 2023 at 7:36 PM
    Moog doesn’t make their own parts, so I guess it’s a Moog point. :rimshot:
  9. Dec 13, 2023 at 8:20 PM
    albru2
    Hey Shifty, they appear to be the same part for '02's: https://parts.capitoltoyota.com/oem...kcmEmeT0yMDAyJnQ9bGltaXRlZCZlPTQtN2wtdjgtZ2Fz
    well shiiiiiiit, looks like someone needs to read your article on finding part numbers a little more thoroughly lol. My local dealership kind of led me astray with the description below but I see now on the amayana site that they are different. Thanks once again Shifty!
  10. Dec 13, 2023 at 8:24 PM
    albru2
    Those are stainless steel zip ties I was trying out from Amazon. But yeah not quite as substantial as I was hoping
  11. Dec 13, 2023 at 8:44 PM
    albru2
    apparently even OEM can fuck up their own left boot because I ordered two 45536's which the diagram would indicate is the smaller one. I guess I just get 45535 now and hope it's the smaller one
  12. Dec 14, 2023 at 5:08 AM
    It’s not just you. I fell into the same trap, if you scroll a bit farther down into that post where I put the numbers you’ll see where I say, “oh shit gotta edit my post above!” ;) Didn’t want to screw anyone later.
    I also saw the “Left, Right” and assumed it was identical and said it was same. Then I started to dig around… and found it’s not the case!!
    I also pointed that out in that thread. The part number ending in “35” in the diagram points to the part number with “36” and vice versa. Best thing to do is see which part you ordered double of last time and change the number accordingly. Like if you ordered two of 36 last time. Order one of 35 this time.
    Just to help out, which *did* you order two of last time? And which clamp, if you got the OEM Oetiker clamp? What side was that boot you ordered for, pass or driver?
  13. Dec 14, 2023 at 11:58 AM
    albru2
    Haha ok yeah, I see your post now and that you've been through this already. I get it now though. I ordered the 36 so now I'll order the 35 and the correct clamps while I'm at it. I need to study that corner of shame thread and see if I can actually do my next project without screwing something up!
  14. Dec 14, 2023 at 12:23 PM
    Mistakes are growth, in a painful and sometimes expensive wrapper. Mistakes may suck, but growth is good.
  15. Dec 14, 2023 at 12:29 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I just did parts store boot and worm clamp its not a vital part as long as it keeps moisture out.
  16. Dec 14, 2023 at 12:34 PM
    ... and stays in place, so both ends remain sealed.
  17. Dec 15, 2023 at 1:21 PM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Worm clamps work fine. I initially ordered the correct different boots and clamps only to need to take them off again. Can't reuse them like you can worm clamps. Get boot clamps on ebay/Amazon and then either OEM or local parts store boots work. The point of them is to keep dirt out and grease in. Doesn't matter otherwise.
    Unfortunately my rack still sucked and I ended up replacing the whole thing. 2WD and 4WD show different part numbers, but then any rebuild place has only one option. I don't think they're different, just a reason for Toyota to charge more. Prices fluctuate a lot on these, but at the end of the day, after ~20 years, it's good to just get a new rack. So much tighter now.
  18. Apr 21, 2025 at 9:40 AM
    fishordie
    fishordie New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    ok...that was good.:rofl:
