Steering rack 08 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Nastynat85$, Mar 25, 2021.
  1. Mar 25, 2021 at 6:50 AM
    Nastynat85$
    Nastynat85$ [OP] New Member
    Garrett
    08 crew max 2wd
    Max trax lift borla exhaust
    Hey guys new to the forum just bought a new to me 08 tundra crew Max 2 Wheel Dr. Been fighting steering wander my steering wheel is semi-tight and started at the rack bushings first because they were worn then went to ball joints then went to struts in my truck still wanders all over every bushing on the control arms are good truck is lifted with a max tracks lift with SPC upper control arms had truck in line for different times three different shops still all over the place now it squeals the tires whenever it hits the yellow or white lines the funny part is when I park the truck sometimes wheels are straight sometimes one is negative to toe I feel like my rack and pinion some thing is wrong it is leaking a very minimalAmount on the driver side not much I guess my question is before I spend a lot of money on a new rack does it sound like my problem
  2. Mar 25, 2021 at 7:47 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Usually a steering rack is pretty hardy and hard to damage. If it is leaking then it is probably introducing air into the rack which could lead to slop in the rack, the air will purge out into the reservoir, but may cause a spongy reaction in the rack. You may not see that in your steering wheel but the rack could drift from the leak. Also, it could be the tires you are running on the rig doing that. The leak did not bother the other mechs looking at your rig?
  3. Mar 25, 2021 at 8:22 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Mileage?
  4. Mar 25, 2021 at 5:45 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Did you get a printout of the alignment specs?
    Type and condition of tires and wheels?
  5. Mar 26, 2021 at 3:27 AM
    Nastynat85$
    Garrett
    08 crew max 2wd
    Think I found few issues last night rack is leaking pretty good now when I removed bellow again to inspect and front wheel bearing lasted a week and one is shot again .. also Tires are worn on the tread from previous over never rotate them like 70% putter edge and 50% inner all 4 are like this . I knew bettter on the tire part . It has 180 k miles and org appear rack or at least been on there a while.. yes truck is lifted with a 6 in max trax kit = no front sway bar and on 37 in tires .. sooooo I think a rack new koyo/blue pit bearing and some tires will fix it .and 3 k later we see what happens
