Steering pump squeal
Discussion in '1st Gen Tundras (2000-2006)' started by Skyler180, Sep 14, 2018.
  1. Sep 14, 2018 at 11:31 PM
    Skyler180
    Skyler180 [OP] New Member
    Cyrus
    05 tundra sr5
    I have a 2005 tundra sr5. I recently put a kandn air flow in it and started to get a squeal coming from the power steering pump. Only for about 10 minutes when the truck is cold. Once it warms up it goes away. So I drained all the fluid ( was pretty dark ) and put new synthetic atv in it. Let the system run and tried to get the air out. The squeal has gotten worse and worse. So I took the belt off and noticed the pump pulley had about 1/4 inch play in it. so I bought a remain pump from lordco and put it in. Only to notice this pump also had the same amount of play in it. After installing it I topped it up with fluid and agin tried to get the air out. But that has not helped the squeal at all. Was told it could be a clogged line but my steering is always smooth cold or warm. There is no leaks in the system. And the fluid stays at the same level all the time. Am I doing something wrong or could it be the pulley? Is it not suppost to have any play at all?
  2. Sep 15, 2018 at 7:13 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Is it a constant squeal or when you turn the wheel? And it still does it for 10 min with the new pump? How does the belt look?
  3. Sep 15, 2018 at 7:18 AM
    Skyler180
    Cyrus
    05 tundra sr5
    Yes it’s a constant squeal for about 15 minutes when the truck is cold. Once it warms up it goes away. The belt looks brand new
  4. Sep 15, 2018 at 7:24 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Does the squeal change pitch or volume in relation to the throttle?
  5. Sep 15, 2018 at 7:26 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Other than a tensioner maybe having a little play I've not known a pulley to have play. Doesn't mean it's not possible I guess, but that seems like a good way to throw a belt. Given the age of the vehicle I'd probably replace all of the bearing pulleys. I don't think the power steering pulley has a bearing on the pulley itself so that seems unlikely. Are you sure it's the steering pump that's doing it? There's an Ask a Mechanic thread running around here somewhere that you can post your question to as well. @Roman might be able to verify if there's any play on a new one.
  6. Sep 15, 2018 at 8:43 AM
    Skyler180
    Cyrus
    05 tundra sr5
    It doesn’t seem to get louder or change pitch. It gets a tiny bit louder when I give it gas but not much at all. I haven’t changed the belt only inspected it but it goes away when it heats up so I thought maybe being a clogged line. But if it was a clogged line then it should effect the way the truck steers. Which it does not. I’ll try a new tensioner pulley and belt and see if that does the trick. Does anyone else have any play in there power steering pump pulley on there Tundra’s ??
  7. Sep 15, 2018 at 9:12 AM
    Professional Hand Model
    Hand Protectors
    Interested in this thread as I’m curious on my next 200k mile timing belt change whether/if all pulleys etc should be replaced at the same time since everything is connected. Preventative thinking.
    Black Wolf likes this.
  8. Sep 15, 2018 at 3:08 PM
    Skyler180
    Cyrus
    05 tundra sr5
    The problem has been resolved. So far so good. I changed the bearing in the tensioner pulley as well as the belt and changed the ps fluid again and bled the system. And has seemed to fix he problem thank you everyone for the help
  9. Sep 15, 2018 at 3:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I went a checked my PS pulley and it has no play in it.
    YardBird and Sas like this.
  10. Sep 15, 2018 at 3:10 PM
    Skyler180
    Cyrus
    05 tundra sr5
    Thank you. I didn’t think it should have play in it. I am still worried about that as it is a reman and might just buy a new one from Toyota so I don’t run into future problems
  11. Sep 15, 2018 at 3:14 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oh, I didn't see you got it figured out. Cool. Glad you got it worked out!
  12. Sep 15, 2018 at 3:54 PM
    Hand Protectors
    I checked mine a few weeks back when doing the valve cover gasket change. Felt good and solid. Belt and water pump were changed out at 110k. She is sitting at 158k now.
    YardBird likes this.
  13. Sep 15, 2018 at 4:29 PM
    Sas
    OKC, OK
    Glad you got it figured out!
  14. Mar 3, 2021 at 6:38 AM
    Itmustbeaduck
    Itmustbeaduck New Member
    2013 Tundra
    Not to reopen an old discussion, but I am having the same type of problem. Thought it was the belt, but dressing made it worse. Noise definitely coming from PS pump. I'm going to just buy a new one and will update with my results.
  15. Mar 3, 2021 at 7:25 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Belt dressing is not a good thing to use on serpentine belts. I'd suggest when you do the new pump to put a new belt on and clean any residue off of the other pulleys.
    https://www.daycoproducts.com/why-belt-dressing-is-not-a-solution-to-quiet-a-noisy-belt
    Glock 40 likes this.
  16. Aug 22, 2023 at 12:20 PM
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    How’d it go?
  17. Aug 22, 2023 at 12:44 PM
    Curious: Are you asking for your 2015 truck, or because you also have a 2000-2006 Tundra like everyone else in this subforum?
    The person you quoted hasn't logged in since 2022, at least a year now.
  18. Aug 22, 2023 at 3:42 PM
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    Yikes. Hadn’t noticed the year
    shifty`[QUOTED] likes this.
  19. Aug 22, 2023 at 5:58 PM
    Pro-tip, to avoid getting results from all generation subforums.
    Go to your year's subforum. When using the search, remember to tick this box, and it'll limit your results to only the year range's forum you're in.
    1Tundra5[QUOTED] likes this.
