Steering pump or RACK just went out!!!!!
Discussion in 'General Tundra Discussion' started by csuviper, Jun 28, 2016.
  1. Jun 28, 2016 at 6:56 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Crap. I was backing into my spot at work and the steering pump started making a grinding noise. Got really hard to turn the wheel. After messing with it more the grinding noise stopped but it is very hard to turn the steering wheel.
    :(:annoyed:
    Black Wolf likes this.
  2. Jun 28, 2016 at 7:03 AM
    csuviper
    Broomfield, CO
  3. Jun 28, 2016 at 7:03 AM
    csuviper
    Broomfield, CO
  4. Jun 28, 2016 at 7:07 AM
  5. Jun 28, 2016 at 7:19 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Ouch. That's a good $400 part right there. Hope it all works out brother. :(
  6. Jun 28, 2016 at 7:25 AM
    I thought I remembered reading somewhere the 2012's had an issue with the pumps going out
  7. Jun 28, 2016 at 8:00 AM
    csuviper
    Broomfield, CO
    Could be the steering rack. That is a fairly common thing for lifted trucks.
  8. Jun 28, 2016 at 8:11 AM
    Mike Tread lightly.
    south carolina
    To me from what I can tell your pump has failed. Hard to really hear it for sure... any play in the steering wheel than normal? If not bet is pump failure unless you had seal failure in the rack..
  9. Jun 28, 2016 at 8:18 AM
    csuviper
    Broomfield, CO
    No play in the steering wheel. Everything was fine. Weekend camping trip to the mountains was fine. Trail was closed so no offroading. Drive in to work this morning was fine. Stop to back into my parking spot and it started making the grinding noise turning in reverse. Played with it some more and the grinding stopped. No noise and impossible to turn the wheel when not moving.
  10. Jun 28, 2016 at 8:32 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    No need to tag me for help. :p
    Here's some troubleshooting. Multiple symptoms will point to a common issue. See attached.
  11. Jun 28, 2016 at 8:34 AM
    Nor7
    Looks like either low fluid or the pump is going out. Chilton says there's a warning light specifically for the power steering system and it can cause the truck to go into fail-safe (limp mode). I suspect that hasn't happened yet.
  12. Jun 28, 2016 at 8:40 AM
    csuviper
    Broomfield, CO
  13. Jun 28, 2016 at 8:41 AM
    Nor7
    Here's the codes related to the power steering pressure sensor.
    Power Steering Warning Light Circuit
    DESCRIPTION
    The power steering ECU is connected to the combination meter via CAN communication. If the power steering ECU detects a malfunction, the power steering warning light comes on. At this time, the vehicle enters fail-safe mode.
  14. Jun 28, 2016 at 8:58 AM
    csuviper
    Broomfield, CO
    No codes. No dash lights.
  15. Jun 28, 2016 at 9:29 AM
    csuviper
    Broomfield, CO
    No leaks
  16. Jun 28, 2016 at 9:40 AM
    Mike Tread lightly.
    south carolina
    Pump failure then..
  17. Jun 28, 2016 at 9:43 AM
    csuviper
    Broomfield, CO
    That's what I'm thinking.
    Heading to toyota now. Have to use some real muscle to steer.
  18. Jun 28, 2016 at 9:44 AM
    csuviper
    Broomfield, CO
    I would replace myself if I had the time. Just don't with a 3yo and 11 week old
  19. Jun 28, 2016 at 9:48 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Dang!! Sorry man. Let us know how it goes.
  20. Jun 28, 2016 at 11:11 AM
    csuviper
    Broomfield, CO
    Come on Toyota. I expected better. Atleast a toyota.
  21. Jun 28, 2016 at 11:26 AM
    Nor7
    That's your rental? Say it isn't so.
  22. Jun 28, 2016 at 11:27 AM
    Mike Tread lightly.
    south carolina
    I still have the original power steering pump in my 1995 Tacoma... lol 280,000 miles.
    Tierhog and T-Rex266 like this.
  23. Jun 28, 2016 at 12:02 PM
    csuviper
    Broomfield, CO
    @LOTSOFTOYS took at look at my truck. So the fluid level on the outside of the reservoir looks like it was full because of a stain. It was actually completely drained into the steering boots.
    The power steering pump is most likely ok. Will have to have the steering rack replaced. This is going to cost me some $$$.:annoyed:
  24. Jun 28, 2016 at 12:23 PM
    Mike Tread lightly.
    south carolina
    Ouch.. seals broke.
  25. Jun 28, 2016 at 1:53 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    How much is that gonna run?
  26. Jun 28, 2016 at 2:01 PM
    csuviper
    Broomfield, CO
  27. Jun 28, 2016 at 2:14 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
  28. Jun 28, 2016 at 3:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    :(:censored::censored::censored:
    Dang, sorry to hear that and to top it off, you got a hippie rental. when it rains, it pours doesn't it?
  29. Jun 28, 2016 at 3:40 PM
    Definitely really sucks Brian.:sorry:
  30. Jun 28, 2016 at 3:43 PM
    csuviper
    Broomfield, CO
    @LOTSOFTOYS let me know of a place that sells re-manufactured racks. Its called rackdoctor.net.
    Instead of $1,028 for the rack it will net me $387.95.
