Steering moves when suspension is depressed
Discussion in '1st Gen Tundras (2000-2006)' started by Phillipk98, May 12, 2017.
  1. May 12, 2017 at 10:30 AM
    Phillipk98
    Phillipk98 [OP] 05 sequoia
    2005 sr5 sequoia
    So I know I'm over do for new shocks but this is something I've never seen before on another vehicle.
    When I'm driving and say I go over a dip in the road or cruising down the highway and the road gets bouncy I guess you could call it. When my suspension gets really depressed it can cause my steering to be pulled one way or the other. Just on the depress, on the travel up it straightens out.
    Have any of you guys seen this. Is it just from worn down 200k suspension?
  2. May 12, 2017 at 10:39 AM
    KCTundra
    KCTundra -Caeleb
    Caeleb
    Kansas City
    2016 Crewmax Platinum
    3/2 Ready Lift, 35" Nitto Trail Grapplers, 20x10 Fuel Assault Wheels (-18 offset / 4.75" backspace), BAM Budget Exhaust
    This happened to me. If you slide under your truck (no need to jack it up), find the shocks and leafs. Once there, whisper to them that everything will be ok. Should straighten your steering right out.
  3. May 12, 2017 at 11:18 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I've not encountered it with my tundra but it's pretty severe on another car I have... It's called "bump steer."
    As the suspension compresses or expands, it changes the geometry of everything down there... as the springs load up, the relationship of one component to another changes, in my car, the critical change is the effective length of the steering arm... the change in effective length, depending on the design of the suspension either increases or decreases the amount the wheel is turned in. Bump steer is greatly reduced through a rack & pinion system but I don't think you can ever eliminate it.
  4. May 12, 2017 at 11:20 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    bump steer. 200k, could probably use some new shocks
  5. May 12, 2017 at 12:42 PM
    Phillipk98
    2005 sr5 sequoia
    Hey thanks guys. I figured as much. Much appreciation. I think I'm just going to get some blister 5100 for all four corners. Level it out.
    driverdog, joonbug and Law323 like this.
  6. May 12, 2017 at 2:48 PM
    kelly32327
    kelly32327 New Member
    chris
    wakulla springs fl
    2001 tundra trd
    wheeles & tires
    with my truck had almost the same i got 300000+ miles on mine and finally tearing the front end down worn control arm bushings will do it and or worn rack and pinion bushings first truck i have owned with rack bushings...usually tends to wanna go more left then right but no matter what your chasing the truck under breaking
    Phillipk98[OP] likes this.
