Steering issues with 00 4X$
Discussion in '1st Gen Tundras (2000-2006)' started by RIC's 00 4X4, Jan 29, 2020.
  1. Jan 29, 2020 at 11:49 AM
    RIC's 00 4X4
    RIC's 00 4X4 [OP] New Member
    00 4X4 ltd
    Steering wheel does not returnn to center after turn. What's likely cause and what needs to be replaced?
  2. Jan 29, 2020 at 4:39 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Normally caused by an alignment issue. If you haven't messed with the front end inspect it for failed parts.
    speedtre likes this.
  3. Jan 29, 2020 at 5:48 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Make sure those ball joints are in good shape. Many snapped ball joint stories start with "I noticed a creak or the wheel not turning to center or I heard a pop"
  4. Jan 31, 2020 at 10:02 AM
    RIC's 00 4X4
    00 4X4 ltd
    About six months ago, while making a u turn from a stopped position, on a dirt road near my home I felt a sudden drop as if I had hit a large pothole. Turns out a ball joint had broken and with that the left front axle snapped. So, I had ball joints on both sides replaced along with the axle. I'm sure I need to replace the struts. They're still original! Still wondering if I need to replace any of the steering components.
  5. Jan 31, 2020 at 3:57 PM
    Professional Hand Model
    Hand Protectors
    We’ll have you spending thousands before you know it. Seriously, my 2002 received a front rebuild almost 2 years ago. It was much needed as she was real tired. Not sure about your 00 condition, but mine at 155k miles was saggy, sloppy, and squeaky.
    Original Steering rack is still good with a small drip at the bellows.
