Steering from Mushy to Firm
Discussion in 'Suspension' started by Les7311, Jul 26, 2018.
  1. Jul 26, 2018 at 7:51 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    is there a steering shocks or whatever that out there that can be added to increase or have a firm steering?
    Am currently on:
    6 inch RC lift
    4x4
    35’s
    My steering feel mushy since I added the lift. Am used to it, but is there room for improvement?
  2. Jul 26, 2018 at 7:54 PM
    Steering rack going out? Any leaks? All components associated with it, in good condition?
    Les7311[QUOTED][OP] likes this.
  3. Jul 26, 2018 at 7:56 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Could be the caster from the alignment.
    Les7311[OP] likes this.
  4. Jul 26, 2018 at 8:46 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Energy Suspension also makes a bushing kit that I imagine would help with that too.
    TexasTundra27 and Les7311[OP] like this.
  5. Jul 26, 2018 at 9:15 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I'm on my 2nd set of poly rack bushings. I haven't noticed any firmness from them.
  6. Jul 27, 2018 at 3:08 AM
    Les7311
    Rack and all in good spirits and shape.
    Is there a steering shocks that can be installed.
  7. Jul 27, 2018 at 3:28 AM
    Not to my knowledge since the Tundra has a steering rack system.
  8. Jul 27, 2018 at 3:38 AM
    Les7311
    Ok. Am just looking for something to do.
    Truck just boring and I have nothing else to do!!!:spending::crapstorm::rasta::playball:
    Think I’ll go look at hood scoops or train horns
    T-Rex266, aperezsh and ColoradoTJ like this.
  9. Jul 27, 2018 at 4:30 AM
    Professional Hand Model
    Hand Protectors
    You could always polish your under carriage. Alway makes me feel better and gives me something to do.
  10. Jul 27, 2018 at 4:48 AM
    Les7311
    This is no joke
    Decided to drive truck to work this morning - am in a funky groove .... hey, I drove it around the block yesterday.
    Jumped in and turn key ..... “click”
    Think I have a failed battery....
    Yeah!!! Spoke too soon
    Moral: be careful what you ask for!!!
  11. Jul 27, 2018 at 4:51 AM
    Les7311
    Uezzzzirrrr!!!
    You forgot to add the wax part
  12. Jul 27, 2018 at 5:10 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    My steering got to feeling shitty and loose, took a little hunting but basically replaced lower ball joints, inner and outer tie rods and installed the poly steering rack bushings and my truck feels right again. How many miles on your truck?
  13. Jul 27, 2018 at 12:55 PM
    Les7311
    Am at 130K miles
    I guess I could replace those same items. Time to go spend some $$$ on eBay.
    And the “click” = dead battery
  14. Jul 27, 2018 at 1:15 PM
    Berettafan
    Berettafan New Member
    2017 CM
    That is the nature of lifts and big tires.
