Steering column clunking
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chad D., Nov 15, 2021.
  1. Nov 15, 2021 at 5:28 PM
    Chad D.
    Chad D. [OP] New Member
    Western Oregon
    2018 CrewMax Platinum
    2018 Platinum 4x4 CM with power tilt/telescopic column.
    ok fellas, I’m stumped…. My steering column just started clunking. In an effort to better describe, I feel it when driving on my gravel driveway, as well as when navigating uneven roadways. If I quickly whip the wheel back and forth (1/8 turn or less), I also feel it.
    Here’s the kicker…. If I retract the telescopic function 1/2”, it stops. I’d prefer to utilize the entire range of my steering column, and am hoping to hear from someone else that has dealt with this already!
    it certainly appears to be isolated to the column, as retraction of the column wouldn’t change things if it were an issue otherwise. At least not in my little brain, it wouldn’t. I did just install new coilovers and UCA’s, and had an alignment done at a very reputable shop 10 days ago. To be completely honest, I called him and had him check it out today. He’s the one that figured out that it went away with slight retraction of the column.
    Truck drives great, but this clunk has me irritated…. Thoughts???
    Thanks,
    Chad
  2. Nov 17, 2021 at 5:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
